04 Excursion w/Rear AC - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 2 Old 06-05-2013, 05:49 AM Thread Starter
My ex has not cooling very well, I'm getting maybe 10 degrees less ambient temp out of the vents. I hooked up a manifold gauge and I'm seeing 50 psi low and 220 psi high which seems normal to me and I believe is an indicator that the compressor is working OK. I decided I needed to evacuate and open it up to inspect the orifice tube. I found that the orifice tube had a crap load of metal shavings indicating my compressor is starting to fail (3 of the four sections of the tube had shavings where as the last section had no signs of metal).
I've decided at the minimum I am going to replace the compressor, condenser, accumulator and orifice tube as well as flush the lines.
So, I have couple of questions to start.
1) If I replace the compressor, condenser and accumulator and flush the lines, should I just add the total recommended amount of PAG oil that is
listed under the hood? There would still some left in the two evaporators but I guessing it would not be a significant amount, but I am not sure.
2) I've read that it is recommended to replace the evaporator core in the event of a catastrophic compressor failure. I'm seeing metal shavings but I don't know if this would be considered catastrophic although metal is a bad thing.
3) Flushing the rear a/c lines, would this be necessary? I'm wondering if the orifice tube would have protected the rear lines and evaporator.
Thanks!
2004 Excursion 2x2 PSD 6.0 TOWING 8K LB 35' Outback 298RE TT -
ARPS
Edge Evolution (Running Economy Mostly)
OEM HG
EGR DELETE
COOLANT FILTER
Zerex ZXED1
BLUE SPRING UG
TURBO DRAIN TUBE UG
DUMMY PLUGS UG
FUMOTO BLOCK DRAIN VALVES
Prodigy P5
Reese Dual Cam W/D Hitch
SCANGAUGE II
AutoEnginuity Diag SW
morganbryane is offline
post #2 of 2 Old 06-05-2013, 06:21 AM
Term3's Avatar
Check to see if the coolant shutoff valve to the heater core works, check the HVAC doors behind the glove box. My Excursion will make me put on a winter jacket when it's on full blast. Finding shavings doesn't sound good.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
