ES MasterKit, any tips or tricks for the install? - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 4 Old 05-20-2013, 11:40 AM Thread Starter
donbickle707's Avatar
I just received my new Energy Suspension Master Kit for my 2004 Ford Excursion and was just curious if anyone else has installed these and if there is any tips or tricks? I have read in quite a few different places that the track bar seems to be a big issue, any info on this as well? I plan on starting the install tomorrow, 5-21-13, thank you for your time and any help as well!
donbickle707 is offline
post #2 of 4 Old 05-21-2013, 05:21 AM
wngnt954's Avatar
I will be changing my leaf spring bushings next week. I have a hydraulic press from harbor freight I was going to use to press the bushings out.
Sent from AutoGuide.com App
The Family Truckster
wngnt954 is offline
post #3 of 4 Old 05-21-2013, 05:36 AM
rdaffin's Avatar
Be sure to use plenty of lube during assy! The track bar bolts are a real pain but the will move!
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #4 of 4 Old 06-04-2013, 10:04 AM Thread Starter
Trac Bar bushings are done! I used my half inch impact to remove the bolts, didnt even hesitate, had to use a wobble extension to remove the right side due to the transmission lines being in the way though. Burned the old rubbers out with a torch, the outer sleeves I used a air hammer to remove, then I took a half round file to smooth the edges where the air hammer had nicked to remove all the burrs, also used sandpaper to remove any rust inside the eyes themselves. Used a TON of lube and my bench vise to press them in, had to work it in though using a 3/8 extension and a hammer to hep get it started, made sure to use a piece of scrap metal against the new bushing so the vice face doesnt chew it up and they slid right in, no shaving the bushings like some people say to do. The little bit of filing to remove the burrs really helped though as there wasnt a sharp edge for the bushing to get stuck/ripped on.
2006 F-250 Lariat 4x4 6.0 Powerstroke, Rancho Shocks, Rear Airbag Assist, Banks Ram Air Intake, Magnaflow CAT-Back Exhaust.
2004 Ford Excursion Eddie Bauer 4x4 6.0 Powerstroke, EGR Delete, PowerAid Intake/Spacer, 4" Turbo Back Exhaust, Upgraded Oil Cooler, Sinister Coolant Filter system, Blue Spring kit, Warn Hubs, Glowshift 3-in-1 Gauge, Energy Suspension Master Kit, SVT Tuner, Sinister Fuel and Oil Filter Caps, Amsoil Filters/Oil, 06 Headlight Conversion.
