Spring capacity question - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 7 Old 05-10-2013, 07:24 AM Thread Starter
Onefast96svt's Avatar
I'm about to order my front and rear replacement springs. I'm shopping sdtrucksprings.com , and came across diffrent selections using an 00 F350. 1 is 3000lbs for the rear and 4400lbs. For the front I'm probably going with the 2630lb. I'm going to be most daily driving and randomly towing a car trailer and rv. Would the 4400lb to stiff? Also with a bull bar on the front will the front 2630lb springs be enough for a comfortable ride or should I go higher? Thanks for the help.
03 Excursion EB 4X4 6.0L Mineral Gray Metallic,20" machined/black Rockstars 33x12.50, 4" lift,Powerstop slotted and drilled rotors,Rancho adjustable shocks,Studs, looney tune wild,CCV MOD, Red Head Steering Box, EGR delete,6.4 banjo,XDP Coolant filter,4" MBPR straight pipe,280amp Alt,Amsoil oil bypass,Go Industries Bull Bar,6000k HIDs,ScanGaugeII
96 Cobra, way too much to list!
Onefast96svt is offline
post #2 of 7 Old 05-10-2013, 08:29 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Do yourself a favor..get springs from ford, X codes for the front, do modded B codes for the rear.
CT Performance, Inc. is offline
post #3 of 7 Old 06-01-2013, 08:57 PM Thread Starter
Still haven't ordered my springs. Has anyone out there bought from sdtrucksprings.com ? I know caryt will say buy them from him or ford but I can't see paying twice as much if they will do the same thing. Please some one shed some light here. I've got the 43-818 at 2630lbs and the 43-1261 at 3000lbs in my shopping cart. Any help from a previous buyer at sd trucks would be great.
post #4 of 7 Old 06-01-2013, 09:01 PM
dieselmatt's Avatar
Quoted: 4 Post(s)
Cary, would you mind elaborating as to the reason behind these choices?
dieselmatt is offline
post #5 of 7 Old 06-03-2013, 01:34 AM
Therabbittree's Avatar
Cary's Modifications work. They have been around since 2004 for almost 10 years... Here is a old chart from a thread I had back in '09 on Diesel Stop, I just added new part #'s from the part # sticky thread in the org's general 6.0L section:
X Codes..F81A-5310-AFA, stamped #3034AFA, Suffix AHD, Weight 2,600lb.
W Codes.. ? - ? - ? -?-?-, stamped # ?-?-?-?- , Suffix AGD, Weight 2,400lb.
V Codes..2C3Z-5310-HA , stamped #3C34ADA , Suffix AFD, Weight 2,200lb.
U Codes..2C3Z-5310-GA , stamped #2C34ACB , Suffix AED, Weight 2,000lb.
T Codes.. ? - ? - ? -?-?- , stamped #F81AADD , Suffix ADD, Weight 1,800lb.
S Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix ACD, Weight 1,600lb.
H Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix HA, Weight 2,250lb.
G Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix GA, Weight ?
D Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix DA, Weight 1,980lb.
C Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix CA, Weight 1,780lb.
B Codes.. ? - ? - ? -?-?-?, stamped # ?-?-?-?-?, Suffix BA, Weight 1,680lb.
5C34 5310 AHB-----------------------------4,000 FGAWR
5C34 5310 AGB-----------------------------4,400 FGAWR
5C34 5310 AFB-----------------------------4,800 FGAWR
5C34 5310 AEB-----------------------------5,200 FGAWR
5C34 5310 ADB-----------------------------5,600 FGAWR
5C34 5310 ACB-----------------------------6,000 FGAWR
5C34-5310 ABB-----------------------------6,500 FGAWR
5C34 5310 AAB-----------------------------7,000 FGAWR
Front Spring Part # vs Code - Page 2 - Diesel Forum - TheDieselStop.com
Therabbittree is offline
post #6 of 7 Old 07-20-2013, 01:32 PM
PowerStrokedRedneck's Avatar
I did Cary's VB spring mod. I bought mine from a salvage yard for $200 total. The front spring I got had a leveling kit already on them. Total lift of 4" over where I started. The ride is 100x better. I'm not fighting it while driving anymore.
Sent from AutoGuide.com App
PowerStrokedRedneck is offline
post #7 of 7 Old 07-20-2013, 02:19 PM
xpbprox's Avatar
X10 on going with OEM. They will last longer and handle good
04 F-350 XLT FX4 CC LB SRW leveled, SCT w/ innovative tunes, Edge Insight gauges, Str8 pipe, Studs, Bulletproof EGR, valve seats, 6.4 banjo bolts, updated fuel pressure spring
89 F-350 Centurion Lariat 4X4 CC BB STW lifted on 35"s
460 E4OD
6.0 BIBLE
xpbprox is offline
