30mm Rear Swaybar Installation Part #'s - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 17 Old 05-07-2013, 07:47 AM Thread Starter
For those of you who do not have a factory rear swaybar and want to install one I finally managed to track down all the necessary part #'s needed to add a 30mm rear swaybar.
F81Z5A772AA 30mm Rear Stabilizer Bar
E5TZ5486B Stabilizer Bar Bracket (2)
1C3Z5705AA U-bolt (2)
3C7Z5K484EA Endlink (2)
E5TZ5B498AA Stabilizer Bar Mount Bracket (2)
The washers in the pic I ended up not needing.
I purchased these parts from tousleyfordparts.com
All metal flanged center-locknuts you can source locally.
M10X1.5 (4) for the u-bolts
M12x1.75 (4) for the endlinks.
ID:	107833   Click image for larger version
ID:	114241   Click image for larger version
ID:	114257   Click image for larger version
Tommyquest is offline
post #2 of 17 Old 05-15-2013, 07:22 AM
What was the total cost?
Luke Duke is offline
post #3 of 17 Old 05-15-2013, 12:02 PM Thread Starter
About $223+shipping.
post #4 of 17 Old 05-15-2013, 12:08 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Hmmmmmmmm.....
2000-7.3L is offline
post #5 of 17 Old 06-07-2013, 05:08 PM
BucOff's Avatar
Outstanding. This is the next mod on the list...
Sent from AutoGuide.com App
Stock Turbo / Stock Sticks
439 rwhp/863 lb/ft.
BucOff is offline
post #6 of 17 Old 11-06-2013, 03:39 AM
jeffro22's Avatar
Quoted: 5 Post(s)
I already have a sway bar on my 05. Not sure if its factory or not. anyone know how to tell what I have and if the 30mm would use and of the same parts if I did the swap out, or would I still need the complete list above
jeffro22 is offline
post #7 of 17 Old 11-06-2013, 01:05 PM
If you already have the factory bar you will only need the bar and the rubber bushings. My bar came with the bushings on it.
2005 Eddie Bauer X 6.0
2005 Limited X 6.0
2008 F350 6.4
Yes it's true, I am the most interesting man in the world.
Dos X's!
Tom Doniphon is offline
post #8 of 17 Old 11-06-2013, 01:42 PM
Term3's Avatar
Quoted: 2 Post(s)
My Excursion came with I believe a 25mm bar, wondering if going up 5mm in diameter will be that noticable?
Term3 is offline
post #9 of 17 Old 11-06-2013, 03:02 PM
Yes it will make a difference. I think the original was a 24mm.
2005 Limited X 6.0
2008 F350 6.4
Dos X's!
post #10 of 17 Old 11-13-2013, 07:52 AM
were did you purchase?
johnrowdy is offline
