Time to buy monitoring guages - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 12 Old 04-21-2013, 10:09 AM Thread Starter
I have an 04 Ex with 125k miles on it. I know some big expenses will be coming with head bolts, EGR delete, etc. For now, I want to make it last as long as possible in stock condition while I save up for the big fix. The only modification it has right now is a turbo back larger exhaust (was on it when I bought it).
Unless someone points out a better system, I am going to get an Edge Insight CTS.
1. What should I monitor?
2. What do I look for to tell me a problem is looming?
3. Will the Insight tell me everything I need to know or do I need to get add ons? (i.e. EGT)
Thanks in advance for the info.
Keith S is offline
post #2 of 12 Old 04-22-2013, 08:14 AM
Brew_WY's Avatar
Garage
An extensive right up can be found in the General 6.0L Discussion area.
Most basic questions have been answered and the search tool can be your best friend.
Welcome to the .org!
Cheers,
Brew
2003 6.0L PSD Excursion Limited 4x4
Edge Insight CTS w/Dash Pod, EGT, TT, Back Up Camera
AMSOIL with REV-X
AMSOIL Bypass Oil Kit
GDS Fuel Spring
Diesel Site Coolant and Transmission Filters
Brew_WY is offline
post #3 of 12 Old 04-23-2013, 11:18 AM
Therabbittree's Avatar
I Like Autometer Guages, I've been using them for years. The Sport Comp II's led light up green at night and are black in the daytime, matches the ford dashes well. I would do EGT, Boost, Trans temp, Fuel Pressure, and HPOP.
A scan Guage II is great and cheap too allows you to scroll thru and watch tons of things.
here are pictures of mine in my '05 Excursion
Thanks,
Deo
Therabbittree is offline
post #4 of 12 Old 04-23-2013, 11:32 AM
Term3's Avatar
I do a lot of driving at night and I find most gauges very distracting when it's dark. With my Dakota Digital gauges at night all I see are these floating numbers of which I have nine inputs I can see at one time on set of four gauges. I have a tire pressure gauge in top quad pod spot which they no longer carry, Time to buy monitoring guages-imageuploadedbyautoguide1366741844.477477.jpg
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 12 Old 04-23-2013, 12:06 PM
In my picture mine are turned up, you can dim them with your regular dimmer, and add a led dimmer from Autometer to adjust it finer... I normally run them about half way dim at night. I need to find the source that had the fuel pressure fitting and flex hose adapter, as the HPOP pigtail makes it easy to hook them up.
Thanks,
Deo
post #6 of 12 Old 04-23-2013, 12:19 PM
sprksonu's Avatar
i like the SCT livewire ts it is a monitor and tuner in one
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #7 of 12 Old 04-25-2013, 08:36 AM
Term3's Avatar
I like the ability to see all my gauges with one scan of my dash and not having to chose what few I want to display on a little screen.
Term3 is offline
post #8 of 12 Old 04-25-2013, 11:06 AM
lx_2nv's Avatar
I have the CTS and added the EGT. I monitor EGT, EOT, ECT, trans temp, boost, FICM V, Battery V, and one more....damn why cant i rememeber the ninth one.
Tom Brown
2004 Ford SEXcursion Limited 6.0
1991 Ford Mustang LX 5.0
lx_2nv is offline
post #9 of 12 Old 04-25-2013, 02:29 PM
Brew_WY's Avatar
Garage
One reason is that the CTS can only display a maximum of eight PID's.
AMSOIL with REV-X
GDS Fuel Spring
Brew_WY is offline
post #10 of 12 Old 04-26-2013, 04:33 AM
lx_2nv's Avatar
I guess I got the one off model - or I can't count!
Tom Brown
lx_2nv is offline
