Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Ford Excursion Discussion
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 02-13-2008, 05:42 AM
thunderinms thunderinms is offline
Sic Semper Tyrannus
Send a message via Yahoo to thunderinms
Suspension Question
My '03 Ex 4x4 has its original stock suspension. The original owner put some cheap shocks on it over a year ago. It rides pretty pitiful at times. My question is with my tax refund coming in soon, what shocks or other mods should I do to smooth the suspension out?
Garrett
Old 02-17-2008, 10:46 AM
jonylost jonylost is offline
Cool
First I would ask........define a pitiful ride. You are a leaf sprung rig and you will not run as smooth as the coil sprung 2x4 brothers. But if you suspect shocks as a culprit, maybe bouncing too much or bottoming out type problems, I have been a Rancho fan for ever.
I have owned 2 of these beasts, a 2x4 2001 7.3 and now a 2004 6.0 4x4. Very different rides between the two.......
HTH
Old 02-17-2008, 11:26 AM
Diesel Freak Diesel Freak is offline
Rice Hunter
Comfort in ride would be first and for most imo!! Safety also if this thing is bouncy!
Good shocks make a difference! Some lift kits offer the cheapest shocks unless you UPGRADE!!
Old 02-17-2008, 11:34 AM
20046.0PSDX 20046.0PSDX is offline
Bilsteins do awesome. Also to prevent some wandering a rear Hellwig swaybar is priceless.
Amp
Old 02-24-2008, 06:09 AM
GISRules GISRules is offline
Send a message via Skype™ to GISRules
Check these out.....I am running these Pro Comp ES9000 Shocks on a stock '99 F250 4x4
7.3l. Work great and are far cheaper than the rs9000's.
Pro Comp 922508 - Pro Comp ES9000 Shocks - summitracing.com
Old 02-24-2008, 06:29 AM
tollen17 tollen17 is offline
Send a message via Yahoo to tollen17
Man you could guess and guess - Ask and ask take your rig to a Front End shop and let them fig. it out. sug. Get your truck level, it will make a big difference on the ride - shocks, add-a-lief, stiffen everything up. pretty cheap fix.
