Upgrading headlamps - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 11 Old 03-21-2013, 01:02 PM Thread Starter
Upgrading headlamps
So I have an 03 excursion, and I'm wanting to get 05 Harley HL, I have the thread on how to cut the header panel, I'm just wondering about an hid conversion kit, and if the one I have now will work on the 05?
And also how the pigtail works, does it plug into my harness now, then I buy hid's for an 05 model? And which pigtail would be the best for what I will be running. HID's
Sent from AutoGuide.com App
corycicuto is offline
post #2 of 11 Old 03-21-2013, 01:08 PM
BucOff's Avatar
Re: Upgrading headlamps
You need to swap out for the 05-07 H13 headlight pigtails. Once you have done that, the H13/9008 HID kit will be required.
Stock Turbo / Stock Sticks
439 rwhp/863 lb/ft.
BucOff is offline
post #3 of 11 Old 03-21-2013, 01:10 PM Thread Starter
Upgrading headlamps
Do the pigtails just plug right in??
post #4 of 11 Old 03-21-2013, 01:14 PM
BucOff's Avatar
You will have to cut the existing pigtails off and install the H13 pigtails. Its a simple straight forward swap. Once completed, the new pigtails will pkug directly into the harness/ballast of the H13 HID kit. Make sense?
439 rwhp/863 lb/ft.
BucOff is offline
post #5 of 11 Old 03-21-2013, 05:30 PM
wckdpowerstroke's Avatar
You can buy an adapter to convert the 9007s to the 05. I have harley lifts to put in mine also. I have had them for a while. I cant remember where i bought the conversion pigtail but it plugs into our factory harnesses And the other end into the newer lights
Black harley lts w/5k hids , blacked out tail lights w/leds,front & rear maghytec diff covers filled w/amsoil, 3" level kit w/ 3" rear block and 5100 bilsteins. 20" novakanes on 35 toyo mt's. kenwood touch screen w/amped kenwood door speakers w/ jl 10w3 subs, optima batts,ipr egr delete,5" sinister stainless exhaust,livewire ts w/egt probe,roof rack removed,mac air intake, blue spring mod, sinister clnt filter,clnt flush & filled w/elc
To do- make custom air box
wckdpowerstroke is offline
post #6 of 11 Old 03-21-2013, 05:33 PM
BucOff's Avatar
Are you referring to these?
439 rwhp/863 lb/ft.
BucOff is offline
post #7 of 11 Old 03-21-2013, 06:31 PM
Yep those are them!
post #8 of 11 Old 03-21-2013, 09:33 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
See HID's are so F'ING confusing. What about a complete retrofit with projectors and all?? Would I still have to splice the existing wiring harness?
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 11 Old 03-22-2013, 03:55 AM
What kind of bulbs in the hids? I would think there would have to be a jumper harness pending on lights. If you are doing direct swaps id think the headlights would be prewired to plug into the headlights. Only think you might have to wire up would be the leds or halos
Here is the guy i use for all my hids. 3bspec.com
He could probably piece something together if you had to. Or he may even know the answer
post #10 of 11 Old 03-22-2013, 11:21 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
We have true Projection Hids....fit from OBS to new.
New True projection hid kits.
For more info email or PM me your email.
Cary
CT Performance, Inc. is offline
