how does yours handle - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 01-03-2008, 09:01 PM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
when it comes to snow and ice my excursion doesn't handle anywhere near as good as my F250. i would think with all the xtra weight it would handle better. it feels like it has a little sway in the tail then when it gets to the end of the sway it wants to break loose. i had a suburban for a while and even that pos chebby did better. but i do love everything els about it.
Old 01-03-2008, 09:10 PM
does the EX have a posi??
Posi's tend to want to have the rear end kick out easier than open differentials. It all has to do with both wheels being locked together and the crown of the road causing them to sway. Ive seen ranger, explorers, F-150's...and superduty/excursions react this way with a posi....they go anywhere in four wheel drive..but dont handle great on ice in two wheel drive...
Old 01-03-2008, 09:15 PM
not posi but limited slip i think.
it feels a lot like having a 100 gal tank with 50 galons in it and sloshing on corners. but no tank.
Old 01-03-2008, 09:17 PM
a limited slip is a posi.........same difference...not a true locker, instead using clutch packs to controll differential lockup as best as possible...
based on your explanation...i think what you are feeling is exactly what i was trying to describe...and its just the nature of a posi or LS differential that is working properly....
Old 01-03-2008, 09:18 PM
My truck is straight as an arrow until i try accelerating or turning back ends so light it just goes its own course. Thats where the fun comes in. But whenever Imon ice or snow I drop her in 4 hi alot easier and safer
Old 01-03-2008, 09:26 PM
ok so its normal... thanks Marc.
i think my p/u has l/s rear also but handles much better on snow and ice i am use to it now and dont drive the excursion as much. it is my wifes so i usually play in my p/u.
Old 01-04-2008, 03:20 PM
i got to UT alot in the winter and drive in some pretty bad stuff..i'm 2wd and everything seems to do fine as long as i say under 15 MPH..after that it's a hellish experience that no one should have to endure..so really it's not that bad..really..
Old 01-04-2008, 09:51 PM
under 15 i would go bonkers. I live in Alaska and drove 81 F150 2WD for 10 years, just threw 150# of sand bags between the wheel wells. My P/U is great on the ice i do very stupid stuff in it and it takes it very well and i am always in 2WD unless I'm on a goat trail or loggin road somewhere.
I am known to bury my speedo regularly on icy roads as long as there is no traffic (like I said pretty stupid).
Old 01-04-2008, 09:58 PM
with mine being 2wd taking off in deep snow sucks especially with 1 tire driving only!!!!
but one you get going it is like a dang tank with the long wheel base and weight of it... this winter I put about 300 lbs of snow in the box after our big snow storm where we got a foot of snow in 6 hrs, and well it went every where I pointed it
