| 6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only. |
On a test drive 2 hrs from home!!
Currently on text drive, how does this CTS look? 41 degrees outside. Deltas over 15 worries me.
![]() What ya think. Otherwise truck is great. Sent from my iPhone using AutoGuide.com App |
Are you able to get the ect above 190? The truck isn't fully warm yet.
Sent from my DROID RAZR HD using AutoGuide.Com Free App |
Before you can test the delta's the truck needs a new thermostat. Tell them to replace it so you can check the oil cooler health.
I was thinking about the therm, been driving for 20 mins or so on higheay
Is there any way to fix it temporarily just so he can check out the deltas?
Sent from my iPhone using AutoGuide.com Free App |
Nope. The thermostat needs to be replaced to allow the engine to come to full operating temps and stay there. If you remove the thermostat or leave it failed open it allows the coolant to flow freely through the radiator to the rest of the cooling system.
Whoa 20 minutes in 41 degree temps wont even get the engine warm enough to open a closed Tstat without a cold front on the truck.
FYI The tstats partially open at 176 degrees and are fully open at 182 |
