| 6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only. |
2005 Excursion Leaf Spring Swap questions
I have a 05 excursion 6.0 4x4. I have read about people swapping F250/F350 leaf springs. I would like to swap my front springs only. Is there a f250/f350 leaf spring that only only lift it 1"-1.5' at the most? I would keep my stock rear springs and put a larger block under them. Thanks!
03 eddie bauer 6.0
I just did mine about 6 months ago and I put F-550 springs on mine because body weighs so much more than even a 450 when hitting brakes hard !!! Only gained maybe 2 inches at most !!
We have everything needed to cure the Excursion handling issues..PM me if I can help.
I put a set if F350 springs under mine a couple of weeks ago. It lifted it up a couple of inches and the ride is outstanding. I then put Rancho 9000s all the way around and a set of Sky Jacker dual stabilizers up front. I wish I hadn't waited so long.
Sent from AutoGuide.com App |
I installed Ford X code front and C code rear. the most common swap is to put in Ford V code front and B code rear. I went for the extra payload.
I got about 5 inches of lift, but after all those miles hard to say how much was the settled springs and how much was over stock. I know I can no longer fit in a standard sized garage. |
Just a FYI, we came up with the modded B code swap and would never advise using B codes un modded.
Me - I just slapped straight C codes on it. I subscirbe to this theory: |
Their is no old or new B code mod their is just the B code mod thats been around since '04. Many like to reinvent the wheel so will try different things, some work some don't and the majority that try have no basis to compair one to another.
Stock rears don't ride well, don't tow well their just lousy springs. Modded B's wide better and don't squat like the stockers. |
Ahhh got it! For some reason I though you had come up with a new setup for the rear.
Cary on...
