2wd Sway Bars
From doing some looking online it looks like my 2wd Ex came with both front and rear smaller sway bars from the factory. I just recently read that we can use the Ford 30mm rear sway bar from the trucks. Looking at Energy Suspension's catalog it appears that my 2wd came with a 29mm front sway bar while the 4wd came with a 36mm unit. Can anyone verify this? If it is true, does anyone know the Ford part number for the 4wd sway bar? Upgrading the front and rear bars and adding in poly bushings at the same time should really make a noticeable difference.
