Engine light on already - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 11-01-2012, 12:13 PM
Hey guys I just had a check engine light on my truck come on. I was excelerating from a stop light (not flooring it or anything) and It dinged and came on. I have not felt anything diffrent in the engine running all temps and gauges are reading normal. I cant afford to take it to the Ford Dealership and have them run the codes (150 dollars). Is there anyway to check it. Or does anyone have reader that I can borrow? I cant afford to have this truck breaking down on my wife and Kiddos. I hope its just a bad reading or something and when I reset it it dont come back!! Please Help
Old 11-01-2012, 01:18 PM
Most Auto parts stores will run codes for you for free not sure about diesels but worth a try
Old 11-01-2012, 04:10 PM
Not Diesels there code readers dont work Found that out when my truck broke down
Old 11-01-2012, 05:59 PM
That sucks i have a mechanic I've been going to for years he would read it for free for me, ford should just read it for free cause it takes them hours to do u know.
Old 11-01-2012, 06:47 PM
Hey the old man that has been working at the dealership for 50 years has to pay for his hip replacement from crawling un and out of these trucks I would ask more money if i would have been asked to work on the guys truck that was there when I went even if it was just plugging in a wire and pushing a button. easly 15 inches of lift and 44 inch tires (oh yeah its the guys daily driver) It had welded bars that dropped from the bumper to pass the Tennessee Bumper Law
Old 11-01-2012, 08:25 PM
I was able to read codes with a regular craftsman code reader. I would try the parts store. You really should get a monitor on this truck anyways, those can read codes in addition to providing you with engine critical information. My scangaugeII does all the code reading and monitoring that I need and it was only $160
Old 11-06-2012, 06:53 AM
The code reader at my local O'Reilly parts store pulled codes from my 03 6.0. The OBD system is the same diesel or gas.
And for 12 bucks you can get yourself one of these and read your codes anytime you want:
Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive
as for your problem - if the engine continued to run fine and you did not see any other lights, gauges etc with a problem, 90% of the time that is an egr code.
Old 11-07-2012, 03:37 PM
Hey a little note that I just found out my reader read my codes MY FICM is going bad. AND NO PARTS STORES HAVE THEM!!!
Old 11-07-2012, 07:45 PM
What are the codes?
ODBII readers are cheap.
Old 11-08-2012, 08:18 AM
you need to do a little research on FICM's here. you really want a quality unit from a trusted source.
