| 6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only. |
front end rebuild kit
who sells a front end rebuil kit for the excursion. 04 4x4diesel eddie bauer
my front end guy told me the following needs to be done: upper ball joints lower ball joints 2 sway bar links drag link inner tie rod center link-outer tie rod outter tie rod front shocks(ive already done this) and 3 seals now comes the questions. the 2 sway bar links do they come whole or can i just replce the bushings in the links? on the drag link can i just replace the greaseable bushing on the end or do i have to replace the whole thing? then the sway bar i am sure it needs new bushings. i do know that all of these parts do need changing. all the rubber is deteriorated and ect. but i wouldnt think the center link and sway bar links would have to be replaced because they are in good shape just the bushings are worn. only noise i have is when i take off from a dead stop it makes a clunk. then when i come to a complete stop. any ideas?? i am really having a pita trying to find a kit to do this. i plan to do this myself with the help of a friend. are there any other parts that i will need to replace in the process such as seals or something like that due to having to pull the hubs to do the ball joints? any tips would greatly be appreciated!! if someone has any reference pictures that would be awesome and a huge help!!!!!!!! |
I can't believe I am the only one that has had these issues.
You can replace the sway bar link and sway bar bushings with with OEM or Energy Suspension components. It's not an impossible job but you more than likely will need a press of some sort. Here's a write up:
http://www.frontiernet.net/~jmray/F250Bushings.htm I am unsure of what the front end set up is like on your year. But for ball joints and indirectly steering components I've done it on a 02 350 and used an article from Superdutypsd.com. http://www.superdutypsd.com/ball_joint_article.php Just my experience, but when replacing steering components drag link, tie rods...I've only used full replacements. On mine, I don't believe the wear points are replaceable independent of the whole link. Hope this helps, Jim Sent from my ADR6300 using AutoGuide.Com Free App Last edited by azc9a7; 06-28-2012 at 09:41 AM. |
I just did that whole job. I was doing ball joints and ended up replacing the entire drag link and tie rod for 195 and ball joint style sway bar links for 65. Just replace the assemblies and never revisit it again. It was a small price to avoid more aggravation. Now a bump stop is needed....arrrgh!
