| 6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only. |
RAP module location 2004 EX
I have tried all of the std locations(removed radio, fuse panel cover, above kick panel, jack panel, removed bag hook panel, glove box, and all I can find is a PATS module. Does anyone have a Ford doc showing where it is on an early 2004?
Thanks
If you find it, let me know because I have done the same searching that you have. I have a word document that has codes that will work. It just takes trial and error to fing one that does. If you want it, let me know and I'll p.M. it to you.
Shop manual says to remove the lower center dash trim to access it.
Keyless Keypad Code - Ford Truck Enthusiasts Forums
Spaceace, I sent you the file and just figured out how to use attachments. Above is a link that through how to find code that works. It might not be the primary code, but you can find one that works. I just realized that at the end of the attachment is the directions to program/try the codes. Good luck to everyone. |
