Bad ficm? - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 12 Old 02-13-2012, 07:53 PM Thread Starter
ford_cummins83's Avatar
Bad ficm?
I just put this excursion back together and it was only reading 12.45v and the ficm was at 32v. I finally ended up putting an alternator on it and it's still saying 12.8 till I rev it up a bit and it goes to 13.6 but the ficm bounces up and down from 38-45 at the most and it's showing a ficm code, just wanted some opinions before I throw a ficm on it..
Also I put the amsoil bypass kit on and the oil pressure gauge included was at about 55psi at idle and after driving it a few times it's at about 25 at idle, is this normal?
04 king ranch fx4, sct x2, cts monitor, zoodad, cai, 5" exhaust, alligator delete, 6.4 banjo's, blue spring, mtw hybrid w/03 wheel, smoked lights, 2012 bumper, mtx stereo sytem
2012 ford fusion -
ford_cummins83 is offline
post #2 of 12 Old 02-14-2012, 03:16 AM
Wed Turner's Avatar
That is definately a bad FICM. Replace it sooner rather then later. Quick Tricks has some good deals on FICM's with lifetime warranties.
I've never put an oil pressure gauge on my Excursion, but based on my experience with ever other vehicle I'd say that is normal. Once the oil heats up and gets more fluid the pressure will drop. Now you should be able to find a standard oil pressure range for a warm engine someplace. Do you have a Haynes manual maybe?
2003 Excursion Limited 6.0 2wd
Transmission built by
/ ECM tunning by
/ FICM tunning by
Coldside Intercooler Kit /
EGR Delete /
Coolant Filter / GoGo Diesel direct clutch solenoid / AFE Stage II Intake / Ford Blue Spring / 6.4 Banjo Bolts / Zoodad / 1.5" front sway bar by
/ Ford 30mm rear sway bar
Wed Turner is offline
post #3 of 12 Old 02-14-2012, 06:12 AM Thread Starter
No powerstroke.org is my Haynes lol.. And that makes sense I guess, it's got 5-40 in it.
Wheres quick tricks, I found a place called ficm fixer for 110 with lifetime warranty
2012 ford fusion -
post #4 of 12 Old 02-14-2012, 09:24 AM
Quoted: 13 Post(s)
Yeah man use the guy from ficmfixer.com , that who I just used $98.00 same day service, and they are local to me so I dropped off, put back in and truck runs much smoother.
99 F-250 7.3-Sold
2002 F350-Sold
05 Harley F-350-Sold
2011 F-250 King Ranch-Sold
2017 F-250 Platinum-Ordered Jan-17
7.3dofbft is offline
post #5 of 12 Old 02-14-2012, 03:55 PM
Wed Turner's Avatar
Welcome to Quick Tricks!.
It's hard to beat that price though if he knows what he's doing.
/ ECM tunning by
/ FICM tunning by
EGR Delete /
post #6 of 12 Old 02-14-2012, 03:57 PM
Quoted: 13 Post(s)
Well all I can say is my truck is running great, he has lots of positive feedback, says he is electrical engineer, and gives lifetime warranty. Says he's never had a unit come back.
99 F-250 7.3-Sold
2002 F350-Sold
post #7 of 12 Old 03-24-2012, 06:04 AM
ChrisB's Avatar
7.3ofbft, thanks for saying that about ficmfixer.com, i was on the fence between ficmfixer.com and ficmrepair.com. ficmrepair.com is a bit more expensive, but they also say they had a 'few ficms come back', but insist they came back because the customer also had an injector problem they didn't tend to.
I was going to give it a shot and attempt to do this myself, to save a $100, but i don't lifetime warranty my work like ficmfixer.com, and I don't want to make anything worse than it already is.
Another to note about the two guys that i mentioned, they don't just re-solder parts/pins, they replace the entire power supply and check for and correct other faulty components within the ficm.
Mine measured 48v at key on, 46-47v during crank, and 31v at engine on. (That was with batteries both measure 12.5v at engine off.)
ChrisB is offline
post #8 of 12 Old 03-24-2012, 07:24 AM Thread Starter
I also used ficmfixer, I took it to him in person and he got right on it and only took him about 45 minutes, his name is Shannon Sizemore, very nice guy and he will be getting my ficm's from now on
2012 ford fusion -
post #9 of 12 Old 03-27-2012, 05:36 AM
excursioninaz's Avatar
i repaired mine last week! soldered the 16points on the back and the 4 little mico boards(that says dale) on the other side, i get 49volts while running(very easy to do)
excursioninaz is offline
post #10 of 12 Old 03-27-2012, 06:40 AM
Just a note about battery voltage and the FICM. Just because the battery holds a charge at 12V or so does NOT mean they are still good. They need to be load tested to be sure. They may hold a charge but when they are placed under load they might be discharging to quickly and be unable to supply enough voltage to glow plugs, starter, FICM and the rest of the electrical components. It's important to have them tested to rule them out as the cause of low FICM voltage and to make sure they don't take out a good FICM.
Just wanted to avoid any confusion between having charged batteries and "good" batteries.
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
