Backup Lights - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 13 Old 01-07-2012, 10:23 PM Thread Starter
VQT
Backup Lights
Besides put in a rear camera, what did you do to your Ex to shine brighter when backing up at night?
JCWhitney sell the lights that hook to the receiver from JCWhitney, is it good?
Thanks
VQT is offline
post #2 of 13 Old 01-15-2012, 05:17 AM
Heathrm's Avatar
I found this thread a while back and saved it, it might give you some ideas. It includes the wiring/relay information to help you out also. It is a long thread, but there is a different options you could go with. Hope this helps.
2004 Excursion Limited, 198,000 miles,
Edge CTS (Gauges only), ZooDad, Turbo Timer, DieselSite Coolant Filter,
RCD EGR delete, CCV reroute, Amsoil By-pass Filter, FireStone RideRite Air Springs,
FICM from Ed with Atlas 40 tune, No Kitty, FPR Blue Spring, DC XP270 Alternator
Heathrm is offline
post #3 of 13 Old 01-15-2012, 05:47 AM
couldnt you just wire driving lights right into your factory back up lights under the truck.
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #4 of 13 Old 01-15-2012, 05:50 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 275 Post(s)
I had the White Knight unit on my truck and it goes around the receiver and let me tell you if you change out ball mounts a lot and even just tow a lot they are a pain in the a$$. I just got some small rectangular halogen lights and some self tapping screws and mounted them to the bottom of the trailer hitch.
strokinpower is offline
post #5 of 13 Old 01-15-2012, 07:32 AM
Heathrm's Avatar
The wiring diagram/relay set up is to put them on an upfitter type switch. I wouldn't want them coming on all the time when I put it in reverse. I also would want the option of just putting them on if I wanted to, for extra light. I wanted to have the flexibility of using them whenever I wanted.
Heathrm is offline
post #6 of 13 Old 01-15-2012, 09:26 AM
Java's Avatar
I put a rigid industries "dually" LED light and it works awesome!
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #7 of 13 Old 01-15-2012, 09:41 AM
trophy_23's Avatar
I just used the largest zip ties I could find and secured them to the hitch, grounded them at the back of the truck and ran 1 wire up to my upfitter 1.
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
post #8 of 13 Old 01-15-2012, 04:33 PM Thread Starter
VQT
How did you attach the wire to the truck backp lights? Did you have to use a relay and diodes? What about how did you guy going about install an independent switch to turn on/off at will how did you run the wire up the to driver cabin?
Thanks
VQT is offline
post #9 of 13 Old 01-15-2012, 05:54 PM
trophy_23's Avatar
Mine are strictly on off with a switch, they are not connected to the trucks lights at all. I went down the drivers frame rail, then up through a grommet in the firewall to upfitter #1.
High Idle
Duraflaps
Dually ID Bar
post #10 of 13 Old 03-10-2012, 06:54 PM
Quoted: 3 Post(s)
Do you have the link? Thanks.
2005 Excursion Limited 6.0L 2wd
Atlas 40, Bulletproof EGR cooler, coolant filter, 6.4L banjos, Cat coolant, Gogo direct solenoid, 7.3 fan clutch. Otherwise, all stock.
bigric is offline
