6.4 Banjos vs OEM - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 2 Old 01-06-2012, 09:58 AM Thread Starter
6.4 Banjos vs OEM
Guys I'm green when it come to the entire diesel thing so please work with me. I see guys telling of having different size banjo bolts, I understand this is a fuel line up grade.... For what, what are you gaining by this up grade, the only thing I can think of is going from OEM to 6.4 banjos allow more fuel volume to be delivered. Where are they located, the reason I'm asking is when I order my Blue Spring upgrade is this a good time to order the Banjos????
(While I have everything apart is this a good time to install the 6.4s) Any info will be greatly appreciated.
TY,
NT4N
NT4N is offline
post #2 of 2 Old 01-06-2012, 10:16 AM
Term3's Avatar
Quoted: 2 Post(s)
A lot of guys use them as they flow more fuel. Do they actually make a difference, IDK. Some guys say not to use them due the check valve difference. Take care not to twist the fuel lines when you unscrew the old ones.
6.4 banjo bolts (2 needed)
Part # W302472
Washers for installing banjos
(4 needed)
Part # W303659
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
