EGR Delete or Bullet Proof EGR suggestion - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 10 Old 12-14-2011, 10:59 AM Thread Starter
2005 6.0 need suggestions for which brand to go with.
NT4N is offline
post #2 of 10 Old 12-14-2011, 11:44 AM
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Feedback Score: 4 reviews
I went the BulletProof route since we have emissions inspections here in Arizona. I went through 4 of the stock EGR coolers in the first 100k miles, but this one is still going strong after about 2 years. The stockers would have NEVER lasted this long.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 10 Old 12-15-2011, 09:28 AM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
If it were me I would delete it, no testing where I live.
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #4 of 10 Old 12-15-2011, 09:35 AM
Quoted: 5 Post(s)
Might have a check engine light with an egr delete, need a tuner to keep the light off. I would go with an upgraded egr cooler.
a2elvis is offline
post #5 of 10 Old 12-15-2011, 09:37 AM
novemberdelta's Avatar
Quoted: 3 Post(s)
If you can get away with deleting it that's the way to go.
2015 F-250 XLT
Fisher 8.5' Extreme V Snow Plow
novemberdelta is offline
post #6 of 10 Old 12-15-2011, 09:41 AM
nathan's Avatar
I would delete it if you can get by with it in your state. You won't have to run a tuner to turn off the MIL if you just plug the old EGR valve into the connector and lay it in the intake area. Then again the MIL might not even come on.
[/SIGPIC]
99 superduty crew cab 4x4
95 f250 4x4
91 ID IBronco Centurion (rough) but only 895 miles
86 IDI f250 4x4 (just bought)
2000 custom bike I built
nathan is offline
post #7 of 10 Old 12-15-2011, 10:09 AM
Quoted: 5 Post(s)
Could be wrong, but the egr system is set up to see egr flow with the ebp and map sensor... So if the pcm commands egr valve open and doesnt see the change in pressure poof check engine light for egr insufficient flow. It may not set a code for egr position, but if it has the newer programming it will set a code for egr flow.
a2elvis is offline
post #8 of 10 Old 12-15-2011, 12:44 PM
tec548's Avatar
I just had Garett at Power Stroke Magic delete mine while he was replacing the heads and installing ARPs. No lights and runs very well... again...
04' EX 4x4 Limited, 6" ProComp suspension, Warn heavy duty front bumper with M15k, 84" Safari rack, MT 36/15.5/16 on MT 12/16's, 4" MBRP turbo back exhaust with 5" tip, Edge CTS Evolution monitor, STCx3 Extreme Street tuner, Blue fuel spring, ARP head studs, EGR delete, Coolant filter, 6.4 banjo bolts, Garrett PowerMax Turbo...
tec548 is offline
post #9 of 10 Old 12-15-2011, 12:50 PM
Quoted: 5 Post(s)
2004's wont usually turn on a light unless its been flashed to the newest strategy
a2elvis is offline
post #10 of 10 Old 12-15-2011, 05:30 PM
deamsphelps's Avatar
Damn. I wish I had a shop called Power Stroke magic near me. I have no idea where to go with my truck in the jarrettsville, MD area. so far dine everything myself and no issues yet. Just starting to think about the egr delete idea.
deamsphelps is offline
