| 6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only. |
Slow to accelerate
2004 excursion 6.0...Truck take approximately 100 to get to 15 mph and 1800 rpm's, from this point on the truck runs strong...very difficult to pullout in traffic...After ready through a lot of the posts, i remover the erg and cleaned it, no change...I removed the butterfly assemble that was recommended to remove at the time you cleaned the egr, no change on the bottom, a little on top end...I removed the turbo, cleaned and reassembled, no change on the bottom, a little more on the top end...Also, no codes...what the cure? need help...Thanks...
I'm having the same problem with my 05' 6.0 SD, it's a pig until the turbo kicks in... I'm curious to see what everyone says about your issues...
Keep in mind you have a 8500 lb truck, it is not going to take off quickly. When you removed and cleaned the turbo were you able to confirm the variable position vanes were functioning properly?
Do you see black smoke? The turbo may not be spooling up quickly enough. |
is it revving at all? If so the problem may be transmission. If you are pressing the pedal to the floor and not much is happening that makes me think it is an issue in the electronic throttle.
Sounds like turbo vanes are stuck in the open position... Need to pull turbo to inspect.
I can press the petal to the floor and it will slowly start to move, very slowly until I reach about 1800 rpm's then it takes off strong...When I am driving on the highway and the rpm's are up, no problems, accelerates great...No bottom end at all.
Had the turbo off last weekend and clean it, nice and shiny...I had the problem before I clean the turbo, no change...Is there a way to check if the vane's are functioning while on the vehicle?
I would think you would see smoke with the vanes open. Easiest way to start it up and let it sit at idle and listen. You should here a soft whistle every once in a while. If you have an aftermarket exhaust it will be more pronounced. If your exhaust is constant at idle they are stuck.
There is an electric solenoid that opens and closes the vanes. It cycles full open to full close at idle to check function. note it is supposed to throw a code if it does not cycle. |
