Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Ford Excursion Discussion
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 07-30-2007, 11:18 AM
LittleRadio LittleRadio is offline
Question Sluggish Acceleration off-the-line when Warm
Pardon me if an answer to my problem has been posted somewhere already... I'm having difficulty searching these forums. (Server issues??).
Anyway, my '05 X's 6.0L PowerStroke accelerates from a stop (when warm) as though its turbocharger isn't spinning... either that, or like I'm dragging a 5-ton trailer behind me.
It's not so noticeable when cold... but when the engine is warm/hot, sometimes I pull out into traffic and am frightened by the lack of acceleration. Then I mash the pedal and the engine spools up and seems to finally get going.
Any ideas? This just ain't right for a motor with 560 lb/ft of torque.
Tony
Old 07-30-2007, 05:19 PM
duramaxslayer duramaxslayer is offline
Dont Know but hopefully a Tech will!!
BUMPITY
Old 07-30-2007, 05:25 PM
SCUFFY828 SCUFFY828 is offline
SUPERDUTY GURU
there are several things , turbo may be sticking being the most common , line to map sensor maybe slightly clogged , not very likely but have seen it, ebp sensor bad , vgt solenoid sticking on turbo, egr valve acting up some , need to have codes pulled just to see if there are any , it can set a code with no light on, my
Old 07-30-2007, 05:27 PM
mschn99 mschn99 is offline
Banished
I totally agree with scott's above post...the only other usefull info i can think of is if there is any black smoke and how much...
Old 08-01-2007, 10:29 AM
jayman69 jayman69 is offline
Is it just turbo lag? I just bought a 06 F250 and when I push on the throttle it seems to sit for about 2-3 seconds then it spools and goes. I thought this was normal for the 6.0's. I had a 7.3 before and there is a night and day difference between the two as far as spool up and take off. Maybe there is something wrong with mine to. I will be watching this thread.
Old 08-01-2007, 10:53 AM
thunderinms thunderinms is offline
Send a message via Yahoo to thunderinms
Mine was doing the same thing the other day. I did not get a check engine light though. I will pull the codes tonight when I get home. I was thinking of upgrading the diablo and tuning it to TOW SAFE and trying that...
GG
Old 08-10-2007, 05:44 PM
DFurman DFurman is offline
mine did the same thing, if i mashed on it when i was up to speed it would go like a scalded dog but at idle and initial acceleration i didnt hear much turbo noise. It was a stuck charger!
Old 08-10-2007, 05:57 PM
Rwalker Rwalker is offline
Why So Serious??
Send a message via AIM to Rwalker Send a message via MSN to Rwalker Send a message via Yahoo to Rwalker Send a message via Skype™ to Rwalker
i also agree with scuffy's post. have the codes pulled if any and go from there. i learned that the 6.0's need to be ran a little harder, almost like they are built to beat up on! i had lots of issues before i started to run it harder. so if you are taking it easy on it that may be a cause also, drive it like you stole it!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
