The good old Lift Gate wont Lock fix. - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 02-25-2011, 01:03 PM
The fix is, Buy a New one
Very easy to install, after taking off the Wiper Motor.
Old 02-26-2011, 06:45 AM
I never took out the wiper motor to do mine.
Old 02-28-2011, 08:44 AM
I took off the Piston to get it out,No big deal. But i didnt want to take apart the new Assembly to get it back in, 4 bolts, disconnect the wire plug, it comes right out. With it out the Lock assembly went right in, Remember i all ready had the Whipper Arm off drying after painting.
Old 02-28-2011, 10:07 AM
It would be faster without the wiper motor in the way.
Old 03-01-2011, 11:55 AM
a lot of guys on FTE have basically taken it apart - lubed it and gotten the original to work. I am going to try that first before replacing the entire assembly. Wish me luck...
Old 03-02-2011, 07:51 AM
I tried that, Didn't work,
Yrs of opening and closing that heavy A*S Lift Gate messes up locks. Theres all kinds of posts about none-working Lift Gate Lock on this and other Truck Sights.
Old 03-02-2011, 10:25 AM
did you happen to notice if yours had this problem:
every time I get the car washed, it shows door ajar for several hours.
Old 03-02-2011, 11:14 AM
Take the Lift Gate Molding off and check the door ajar sensors where they lock in to the locks and then the wire connections and check/Replace the Molding.
