Streight Piped the X last week. - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 02-17-2011, 11:42 AM
Well we finaly did it Cut all the factory exhaust off and had a DIAMOND EYE 4in Streight Pipe Exhaust assembly. NO MUFFER-NO CAT and the Sound is AWESOME !!!!!!!!!!
Old 02-17-2011, 12:50 PM
so...think your rear dif might be leaking?
Old 02-17-2011, 06:43 PM
Yep, I'll get to it next week some time.
Old 02-17-2011, 06:49 PM
I know it sounds awesome, exhaust is the best mod haha. But I wouldnt drive to much with that leak cause it looks like a lot
Old 02-17-2011, 07:03 PM
Does anyone know if there's a significant sound difference between running a muffler and not on a 5" system?
Old 02-17-2011, 07:15 PM
O yes. There is a huge difference!!!!
My buddy Will went and took his muffler of his 5" mbrp kit and straight piped it and it sounded wayyyy better when you got down on it hard
Old 02-18-2011, 05:01 PM
It sounds Awesome, But it sure does STINK when we start her up.
Old 02-27-2011, 06:20 PM
With no muffler, no cat and 4 inch piping...is there much difference between all of the exhaust companies?
ie: MBRP, Magnaflow, Diamond Eye?
Old 02-27-2011, 07:20 PM
How is the noise in the cab of the Ex at 50mph to 70mph, is there lots of drone going with the straight pipe? I am getting a turbo back kit and am wondering if I should just toss the muffler.
Old 02-27-2011, 08:34 PM
Diesel Mechanic Poser
Those are some sweet looking parts. I saw your other post, too. Awesome. BTW, how does that pipe fit and why did you get that brand? And did you get the larger replacement turbo drain tube? I would presume that you did since the old one is stacked up with all the other parts. Thanks.
I just have a 4 inch cat-back currently and I think that is an excellent question. I would like to see what sort of comparisons folks can offer based on what they have had before or maybe compare with what they have now and with someone they know. It would probably take a separate thread to do all that.
The first thing that I think of is fitment. The fit and clearance of the downpipe would be pretty important and help set up the alignment of the rest of the system. I know it can be tweaked here and there as you go, but a good start is, well, good. That helix-like bend over the axle would be pretty important to get right if you don’t want vibration in the cab. Then kink-free mandrel bends, then material composition. Those would be some good things to start with in my book.
