| 6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only. |
rear wiper removal/replacement
the spring on my rear wiper appears to be shot as it does not hold the wiper blade snug against the glass. It sits at rest about 1/4 inch of the glass.
How is the wiper arm removed? I do not see a retaining clip. does the cover pop off and it bolt to the motor post? where can I find a replacement arm beside a dealer? |
Carefully Take off the Plastic Cover, Un-screw the Bolt.Then the Whipper assembly will come off with alittle pull. Remember to also disconnect the Water line too
