side mirror replacement - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 01-19-2011, 12:46 PM
Question side mirror replacement
hello everyone. can someone post the procedure to replace the sideview mirrors. i busted my passenger mirror the other day. the mirror is motorized and heated but extends manually. i don't want to start prying of pieces if i don't have to.
Old 01-19-2011, 12:49 PM
Illiana Chapter Director
You have to remove the triangle trim piece on the inside to get to 3 nuts. You also have to remove the door panel to get to the 4th nut and to disconnect the wiring harness.
Old 01-19-2011, 12:56 PM
thanks. sounds easy enough but i think getting the door panel off will be the trick part. any special tools or pry points i need to be aware of?
Old 01-19-2011, 12:59 PM
I think there are just a few screws along the bottom and maybe one behind the reflector. Once you get them out, the bottom of the door panel should pull away easily. Just pull out on the bottom to get your fingers behind it and then lift up. I recommend rolling the window down before removing panel so you don't accidently scratch it and it makes it easier.
Old 01-19-2011, 01:04 PM
thank you very much i appreciate the quick reply
Old 01-19-2011, 01:07 PM
No problem. Good luck on the repair.
