| 6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only. |
Shocks of Choice
Since I found this site it seems that all I've been doing is getting my 2003 excursion better and better
![]() I'd like to replace the shocks, I have the stock suspension with Michelin's tires with OEM wheels, I do have air bags on the back, since I tow a 28 ft enclose car trailer. What would be the best combination of front and rear shocks? Something that won't compromise the ride, but that it will help with the towing capabilities of this great truck. Thanks in Advance |
How do you like the Air Bags? I'm looking at improving the rear capcity of our Excursion. We tow a 31ft travel trailer. This weekend was a little hairy with wind. The back of this turck is too squishy for the trailer and needs some help. I'd like to get it more stable. Did the Air bags help with roll control around conners and staility? I'd like to find out more about good towing shocks also.
Send Caryt a message on here. He sell some Bilsteins for the Excursions and they make a HUGE difference.
1. I can raise the rear and the truck feels more stable with the trailer behind. 2. Towing the Trailer the ride inside feels super nice. 3. Front end is even with the rear 4. we don't have many corners here in Florida but I drove to Atlanta with a big car inside and the trailer felt real good.for sure I have to add some source stability to the trailer, side winds and 18 wheelers are stressfully as the trailer likes to dance side to side to side a lot. Here is a photo of the truck ![]() and one with the bags at 45psi with the trailer
Turbo Wax,
I tow a similar 28' Pace with my 2005 Ex, with the Equalizer WD hitch and Roadmaster Active Suspension kit. Otherwise I'm stock. I've got about 10,000lbs (two cars in the trailer) towing off the hitch and it tows well. It keeps your attention though. I was told I didn't need bags if I used the RAS and so far I've been happy. One windy day going over the Skyway Bridge I was nervous but the rig was steady. I'm looking for Shocks myself and was trying to decide between the Bilsteins and the Rancho 9000's. I'm pretty sure I'm near the limit of the truck but I'm hoping to make a few upgrades to keep everything working well together. Any advice would be appreciated. Joe |
Bilstiens would be the better choice. Also could you install camper trailer sway control arms on that car hauler. I dont see why not, that would improve the side to side sway. Reese hitch sells several sway control systems depending on the weight of your load and length....Good Luck....Steve
I recommend the Bilstiens aswell. Bang for the buck, they cant be beat!
If its a 4x4 you need..V and modded B codes, 30mm Ford rear sway bar and the Correct Bilsteins. You will not belive the difference.
Cary |
I have heard about this suggestion before 30mm Ford rear sway bar thats a OEM part?
Reese hitch is in my parts list but I'm looking for something simple, most of them seem over complicated
Icon FTW!
