05 Excursion Steering - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 4 Old 04-13-2010, 07:25 PM Thread Starter
BlackKRanch's Avatar
My old man has a 05 Excursion keeps telling me how his steering is loose and truck moves too much on the highway. Is there anything to do and pictures to explain would be great.
06 King Ranch
EDGE Insight
SCT (Innovative)
ARP Studs
MBRP 4" with 6" tip (no cat)
Airaid intake
2" leveling kit and rear add a leaf
35 inch BFG all-terrain
5% Tint
40% Windshield tint
Bilstein 5100 Shocks
War Eagle
BlackKRanch is offline
post #2 of 4 Old 04-14-2010, 11:28 AM
Excurvelle's Avatar
Quoted: 3 Post(s)
I adjusted the gear box on mine, it really helped.
On the gear box loosen the nut on the top. Using an allen wrench gently tighten the center nut till it bottoms out than back off 1/4 turn. tighten the outer nut.
Excurvelle is offline
post #3 of 4 Old 04-14-2010, 04:42 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Most of the problem is the suspension system is unsafe for the weight of the Ex. hundreds of posts on this and how to fix it.
CT Performance, Inc. is offline
post #4 of 4 Old 04-18-2010, 08:51 AM
Steering stabilizers help, maybe even a dual. Look up Fabtech site:
4wd 00-05 excursion
They sell dual opposing, or dual stock mount. I have the opposing and like it a lot. It is basically a shock absorber to dampen input from the road into your steering system. If the above post about the steering box gears does not fix it, AND THERE ARE NO WORN FRONT END PARTS, then this could help. Please have the front end checked out. You never know if something is worn, loose, etc.
DUAL STEERING STABILIZER
OPPOSING STYLE
Stabilizer cylinders are mounted across the axle housing in a horizontal opposed position reducing tire shimmy.
STOCK LOCATION STYLE
Utilizing the stock location, two steering stabilizers are positioned back to back from each other to reduce tire shimmy.
2005 F350 SRW, Crew cab short bed Lariat FX4. 85k. BPD HD oil cooler setup, BPD EGR cooler, Scanguage monitor.
2004 Excursion 6.0 - Lots of mods! SOLD!!!
Squid4life is offline
