2005 Ex Lift - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 9 Old 03-24-2010, 06:25 AM Thread Starter
2005 Ex Lift
I have recently bought a new 2005 Ex for my wife. I am looking to put a small lift on it. (2''-4'') I was hoping I could get some insight on recommended lifts and tire sizes. Prices and links to websites are appreciated. I have the factory 16" wheels and don't plan to change those quite yet.
Thanks,
Tex
Tex_Pilot is offline
post #2 of 9 Old 03-24-2010, 06:47 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Welcome to the ORG! I would contact the guys at TruckToyz. They are ORG sponsors and have ALWAYS taken great care of me.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 9 Old 03-24-2010, 06:54 AM
Cory S's Avatar
4 inch on 35's is a desireable lift tire combo like the truck in m sig its on (33's) but here is a pic of my old truck 4 inch lift on 35's on stock wheels
Vegistrokin
2000 XC 4x4
-CORY
Orlando, FL
Cory S is offline
post #4 of 9 Old 03-24-2010, 06:56 AM
DCSpecial's Avatar
Yep, we have a few choices to get some altitude under your stock X.
Do you have a particular tire size in mind that you want to run? i.e. 33s or 35s?
DCSpecial is offline
post #5 of 9 Old 03-24-2010, 07:23 AM Thread Starter
I'm not quite sure. It needs to be small enough that my 5'5" wife doesn't have any problems getting in and out of it, but I want it to be big enough to have a little attitude. Also, I don't know how big of a tire I can run on the stock 16" wheels and keep it from rubbing. Please give me any advice you might have.
Tex
post #6 of 9 Old 03-25-2010, 07:53 AM
DCSpecial's Avatar
With the stock wheels you'll want to stick with something in the 285mm or 295mm width to avoid rubbing.
You could do a 2" lift and some 285/65R16s.
post #7 of 9 Old 04-03-2010, 06:55 PM Thread Starter
I found some nice wheels that I like but I am not sure that the tire and wheel combo will work with a 2.5'' leveling kit. I want to put some 315/75/16 tires on a set of 16x10 wheels. Does anyone know if this will fit without rubbing. Thanks for the help.
If anybody has pictures of a similar setup, it would be appreciated.
Tex
post #8 of 9 Old 04-08-2010, 03:05 PM
I've got almost that exact same setup on mine with what I believe is a 4" lift. Bought the truck like this though.
mavisky is offline
post #9 of 9 Old 04-08-2010, 09:41 PM
I would recommend the 3.5" Spring Hanger kit from Fabtech. I have it on mine, it's not that extreme, but it does give it a tough look. I run 325 65 18's on a 4.61 BS wheel with no rub at full lock. I chose this combo as I have a family including a newborn. The wife loves the truck. I added the bilsteins and the ride and road manners are amazing.
winr_on_top is offline
