New to the 6.0 X and need help - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
post #1 of 2 Old 11-17-2009, 05:39 PM Thread Starter
Exclamation New to the 6.0 X and need help
Well six months ago I bought the truck with 82k on it with the 6.0. Had it all checked out with a scaner and no codes or promblems found. This was done at a dealership. But now it has 90+k on it and my promblems started with the throtle not responding. Then it started to run really rough then cut off when ever it got warm. No I can even get it started. Some times afterwards. I can let it set for a comple of days then it works fine for awhile then it starts actting up again. I had it hooked back up to a comuter and it pulled 9 codes off of it with out a check engine light on. Couple where the EGR which I pulled to clean and left unpluged but since pluged back in, one was for the ICP sensor, Cam Sensor, Crank Shaft Sensor, and fuel fillters which I have replace, and one for low bost. I checked the turbo and i can hear it run the when the truck is running but i have notice a small amount of oil in ethier side of the air supply/bost piping but no signs that it is blowing oil. Please i need some help and ideal.
Thanks
Firecoastie is offline
post #2 of 2 Old 01-02-2010, 11:52 AM
Powerstroke Techie
Fuel filter codes? Please explain.
Cam/Crank sensor codes can be set by stalling.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
