2003 6.0 Excursion - leave it be or "fix" it - Ford Powerstroke Diesel Forum
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
 2Likes
  • 2 Post By Heavy_GD
post #1 of 8 Old 02-17-2017, 04:49 AM Thread Starter
Curious about your opinions.
Recently picked up 2003 6.0 Excursion with 118K miles, now has 120k. As far as I know it its completely bone stock original from factory.
My question is do I do the typical preventative stuff or leave it be if it is showing no signs? I guess I am defining typical stuff as EGR cooler, Oil Cooler, Head gaskets, Head studs, etc. etc. and whatever else I am missing (let me know).
Just curious would you do the work or wait till it shows signs?
Thanks.
jtduncan is offline
post #2 of 8 Old 02-17-2017, 04:51 AM Thread Starter
forgot to mention that I did call a diesel shop in VA, Impact Diesel. They told me that the 03's have a more robust OEM egr cooler and typically don't have issues as the later ones..........
This is what got me thinking.....should I even mess with it if there are no signs.
jtduncan is offline
post #3 of 8 Old 02-17-2017, 04:54 AM
Heavy_GD's Avatar
Quoted: 1647 Post(s)
Feedback Score: 3 reviews
"more robust"? .... thats funny.
I would:
Drain every fluid and replace new (not "flush", just drain)
Put on all new caps and filters
Delete the EGR
And get a monitor, and just drive it
JesseKK and jokester00 like this.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is online now
post #4 of 8 Old 02-17-2017, 07:17 AM
johnnybgood's Avatar
Quoted: 82 Post(s)
Get a monitor and drive it.
I'd do all the fluids/filters/caps, but not the egr delete unless you have to. Start down that road and you might end up with a tuner to delete the CEL. Then one day you try out a tune, then go custom tunes, then eventually break something it's so much fun. Also mechanic might talk you into a new oil cooler during egr delete, since it's right there. He flushes the system, which dislodges crap causing more problems, new cooler or not.
I don't consider head gaskets/studs as typical preventative work. Not at all.
Just enjoy and monitor it imo.
2005 Excursion Limited w/259K+ miles
-Turbo back exhaust -Harley Headlights & Grill
-OEM 20's -FICM Tuner -Torque Pro App
johnnybgood is online now
post #5 of 8 Old 02-17-2017, 07:26 AM
JesseKK's Avatar
Quoted: 73 Post(s)
Garage
Like said above, a monitor is very important!
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is online now
post #6 of 8 Old 02-17-2017, 09:22 AM Thread Starter
A monitor like this? It wouldnt let me post a link b/c I am a newbie - ScanGauge II Digital Data Monitor
Where could I find a list of ideal parameters to watch and good ranges for those parameters. I have an idea of most things I would want to watch but not sure about what the good/acceptable ranges are.
Thanks.
jtduncan is offline
post #7 of 8 Old 02-17-2017, 09:27 AM Thread Starter
OHHHHH I think I found the thread I was looking for title below
Write Up: Monitoring the 6.0L PSD.
jtduncan is offline
post #8 of 8 Old 02-17-2017, 10:24 AM
G8orFord's Avatar
Quoted: 898 Post(s)
Garage
Some monitoring options.
Monitoring Solutions and Options (WIP)
Dexter
2004 F-250SD Lariat CCSB FX4 SRW
DashCommand on PLX Kiwi2 with iMFD
SCT X4 w/custom tunes (currently TSD MPD)
FICM from Ed
PHP FICM tuner (currently Atlas40)
KC Stage 1.5 Turbo
Blue Spring update
IPR Coolant Filter w/manifold
Rotella ELC Coolant (CAT EC-1 rated)
BPD EGR Cooler
New (03/23/14) OEM Oil Cooler - (backflushed 05/10/15 @ ~40K & 07/03/16 @ ~70k)
G8orFord is offline
