Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Ford Excursion Discussion
6.0L Ford Excursion Discussion This forum is for topics relating to the excursion only.
Old 06-29-2009, 07:07 PM
SCDEALER SCDEALER is offline
05 EXC.. 4X4 light is on and wont go off
the 4X4 light is on and wont go off. it is going in and out of 4X4 but when you are in 2WD the 4X4 light is on. if you put it into low range that lights up like it should. any ideas?
Fletcher
Old 06-29-2009, 07:39 PM
Dieseltorkin Dieseltorkin is offline
Send a message via Yahoo to Dieseltorkin
Could be a bad connection at your transfer case plug and/or the sensor
Old 06-30-2009, 01:54 PM
05charcoal6.0 05charcoal6.0 is offline
Send a message via AIM to 05charcoal6.0
i would check that area to
Old 07-06-2009, 10:10 PM
'powerstroke7.3 'powerstroke7.3 is offline
If the 4WD actually stays engaged all the time, there is a piece in the Transfer Case that looks like a hook with a spring on either side. Been known to go bad and cause it to stay engaged all the time. Just some other options if the electronics thing doesnt work out.
Old 07-07-2009, 12:15 PM
Dave Dave is offline
Vikings cheerleaders YUM!
switch or Tcase motor is bad
