will they fit? - Ford Powerstroke Diesel Forum
Old 06-20-2009, 08:26 PM
Send a message via AIM to pistolpete837
will they fit?
will 35x12.5(or equivalent metric size) fit on my 04 on the stock 16" rims, stock height without leveling? until i can get it leveled.
Thanks
Peter
Old 06-20-2009, 08:28 PM
Tennessee Powerstrokes
They will rub, in my estimation. I would wait till i could level it
Old 12-09-2009, 08:41 AM
will they fit with a level kit?
Old 12-09-2009, 08:54 AM
they will fit with a leveling kit... but still rub your leafs.... i had the same size on my truck with a 3.5" leveling kit system and they rubbed the leafs
Old 12-09-2009, 09:00 AM
They will fit, but will be close. I wouldn't put a 12.5" wide tire on a stock wheel, the center will wear and it won't feel as stable as with the proper width rim.
Old 12-09-2009, 10:17 AM
how do you fix it from doing that. i was thinking about doing crager or eagle rims for it. what backspace would i have to do to prevent it from rubbing.
Old 12-09-2009, 10:27 AM
Depends on what year your truck is. For '99-'04 you'll want roughly 0 to +10 offset, so for a 9" wide wheel you want 4.5-5" backspace and for a 10" wide wheel you want 5-5.5" backspace. I run 35x12.50x18 tires on my '03 with 10" wide wheels and 5" backspace (-12 offset) and the tread edge is about 1/4" outside the fenders and at full lock I clear the frame/springs by about 3/4". I would prefer 5.5" backspace to keep the truck sides a little cleaner.
