Roadmaster Active Suspension - Ford Powerstroke Diesel Forum
Old 06-17-2009, 03:16 AM
I am having the V&B code SD springs put on my excursion. Would it make sense to reinstall the RAS since I currently have them installed? The RAS kit number is the same for both excursions and 250/350. I figure it will only help right? Thanks!
Old 06-17-2009, 08:53 AM
Feedback Score: 5 reviews
If you mod the B codes and install the correct Bilsteins and a 30mm SD rear swaybar you shouldn't need them.
You will need a adj track bar!
Cary
Old 06-19-2009, 02:33 AM
I am not doing the mod b codes. I am putting on the 30mm SD sway bar and currently have Bilsteins. Do you think it makes sense to put the RAS back on not doing the mod b codes since I already have them?
Suggestion on best adj track bar to use?
Old 06-19-2009, 07:09 AM
Best adj track bar..Icon's, second best a DOM bar..
Well if your not dong the B codes and modding them I guess so, haven't a clue really.
Think your making a mistake not doing the B mod...costs you nothing.
