| 6.0L Exterior Discussion Body and Accessories Talk |
lift question?
i was deciding on 4in or 6 in lift and iwas told if i got 6 or higher we need new drive shafts because of the angle dont allow of the u joints to work properly is this true?
on your truck the stock length should be fine up to 6 inches. U joint angles can be changed using angled blocks at the axle end and using carrier bearing shims on the other end.
I have a custom drive shaft for my 7" but I did not need one. I ran the stocker for 6 months with no problem at all.
oh ok good deal thanks guys!
As mentioned with a 6" stock driveshafts are fine...just need to shim down the carrier bearing in the rear.
We offer a few different 6" lifts in our webstore for your 05 if you are interested: 2005-2007 F250/F350 SRW 4wd - Truck Toyz Store |
