lift- camber question
877 views 7 replies 4 participants last post by  motone82
i have am 06 quad cab 2x4 and wanted to put a 4-5 inch lift on it. when you lift these trucks it adds positive camber to the wheels because the suspension is extended. is there a way to bring the camber back to where it was with a lift- negative camber- so that the outside of the tires arent wearing quicker?
:ORG welcome:
You need a bracket for that. The bracket would bolt on to the spot where the i-beams are mounted.
