Level out a two wheel drive - Ford Powerstroke Diesel Forum
Old 05-04-2009, 07:02 PM
Has anybody leveled out a two wheel drive by raising the front end? How much lift? What did you use? any pics?
Thanks
Mika
Old 05-04-2009, 07:08 PM
2" coil spacers will level it, and you can run 33x12.50 tires
mine is done with daystar spacers
Old 05-04-2009, 08:36 PM
level? i wish i had a 2wd..that thing would be almost touching the ground
Old 05-07-2009, 03:36 AM
CJ
Did you do the install?
how long did it take if so?
Im not incompetent, just lazy....
4Wheel parts sells it for like 130.
Ends up like 400 installed and alligned.
Very good looking truck, btw!!!
Old 05-07-2009, 03:37 AM
Also, I am assuming you like the ride, and quality of the part or you would have said so on the original post...
Old 05-07-2009, 03:45 AM
One more thing....
Sorry for all the multiple posts...
Were there any additional components required for the install?
Lines? Shocks? etc...
Old 05-07-2009, 07:50 AM
yes I did the install took less then 1 hr
you use the factory shocks and lines , everything you need to install these come with the spacers.. basically a extension stud and spacers
ride quality does not change as you are still on the stock spring..
you will need to get alignment at a shop, that cost me about $100 including the alignment cams that they have to use
Old 05-07-2009, 07:52 AM
Send a message via AIM to helsel_182 Send a message via Skype™ to helsel_182
good luck brother... you can get those leveling kits cheap off of ebay.......
Old 05-07-2009, 08:16 AM
Kam,
No kidding, they have them for $55 on there, and free shipping.
Guess I'll get those and put them on myself.
I just crawled under it a few minutes ago and it looks exactly the same as my old 90 2wd
(just much beefier radius arms obviously...)
Thanks for the tip.
Old 05-07-2009, 08:48 AM
i know i was so mad when i saw those the cheapest leveling kit i can get is like $120 good luck with the install if you need any help let me know
