Anyone running 20x12 with a -44 offset? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-17-2014, 08:32 PM Thread Starter
I have a set of 35x12.5x20 tires sitting here taking up space and can get a great deal from a friend on some 20x12 rims with a -44 offset.....
Where will that put the wheels and tires with a -44 offset?
The truck has a 3" leveling kit and I should not have too much of a problem with running the 35's on a 12" wide wheel as I have seen many do it with minor trimming and pulling the liners back
But my question is where do I end up with the -44 backspacing???
Truck is a 05 F350 CCSB PSD 3" Leveling kit all around...
Thanks guys!!!
2003 PSD 6.0 ECSB
2005 F350 Harley Davidson PSD
KillerMike is offline
post #2 of 6 Old 04-19-2014, 07:03 PM
USNBIP's Avatar
Fuel Throttle -44 offset
I have the Fuel Throttle Deeps in -44 offset. 4 inch lift. Had to do some trimming.
USNBIP is offline
post #3 of 6 Old 04-19-2014, 07:48 PM Thread Starter
Now my problem is I can't even mount these 35x12.5x20 on this 20x12 wheel. Can't seem to mount it with a ratchet straps and a cheetah. Does everyone have trouble mounting 20x12's on 35/12.5?
2003 PSD 6.0 ECSB
post #4 of 6 Old 04-21-2014, 09:08 PM
I run 20x12 with a -44 but I have a 6" fabtech and I had to do some minor trimming it still rubs in the corners at full lock or heavy compresion
2005 F250 CCSB Lariat
6" fabtech lift procomp shocks|dual steering stablizer with ES2000|35" Toyo open country MT|20x12 XD Diesels|Banks ram air intake|Banks turbo back Monster exhaust W cat delete|polished diff cover
Edge Juice Platinum with attitude
Zoodad|Ford bedrug|Amp Steps|2011 tailgate|2012 taillights,3rd brake light,rear view mirrors|paint matched handles,tailgate handles,mirror caps|2013 rear bumper
westcoast is offline
post #5 of 6 Old 04-22-2014, 06:35 AM
AMARILLO05's Avatar
I have 20x12 -44 with an 8 in lift and 37's. Mine rub a little at full turn and some type of spring depression (very little). The reason I went with the Nitto Trail Grappler is because its not a true 13.50 wide tire. Its actually (in the spec) 12.50. This will make a difference stretching the tire out. As far as mounting, you have to find someone that has a quick valve set up or do it the red neck way with some eather and a lighter!
2005 F250 Amarillo
8" Fabtech - Bilstein piggybacks - Firestone Load Bags
20x12 Fuel Hostage - Nitto Trail Grapplers
SCT Livewire - RCD Tunes
Custom Diesel EGR Delete
68mm Powermax RCD Turbo
185cc RCD Injectors
AIRDOG 2 Lift Pump - With regulated return
BlackOnyx Head Gaskets
ARP Headstuds
Oil Cooler and Heads
Flo-Pro 5" with 7" tip
WFO / 74" Custom Traction Bars
Paramount Studded Grille
AFE Stage 2 CAI W/ Proguard 7
Swamps 58V FICM + Atlas 80hp
AMARILLO05 is offline
post #6 of 6 Old 04-22-2014, 06:37 AM
Heavy_GD's Avatar
Quoted: 1656 Post(s)
Feedback Score: 3 reviews
it takes some talent and patience to mount 12's on 12.
But its not impossible.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
