wanting to remove rear blocks.. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-15-2014, 05:18 PM Thread Starter
thewrubelator's Avatar
Hey guys, thinking about removing the rear blocks to drop the *** end level with the front..Anybody have any pics of their trucks (preferbly regular cabs) with the rear blocks removed? Thanks!
2004 RCLB F250 6.0
ARP's, Deleted, etc. Lots of go-fast goodies over the next few months from WPE
thewrubelator is offline
post #2 of 6 Old 04-17-2014, 01:03 PM
HBandy's Avatar
Been thinking about doing this too.
HBandy is offline
post #3 of 6 Old 04-22-2014, 07:37 PM
I have a few buddies who have done it and cut coils. Taking out the blocks will squat the back end lower then the front as long as you have your stock 5 pack leaf springs. The only thing is that when you take the blocks out you have to get custom u bolts made. Basically measure your u bolt from the top to the center of the u and subtract what the block is. Also when you go to tow something now the back end will squat a lot with out blocks. If I knew how to post a pic I could show you.
06sixslow is offline
post #4 of 6 Old 04-22-2014, 08:10 PM
HBandy's Avatar
I was thinking I could place the block on top of the leaf spring and use the same bolts.
HBandy is offline
post #5 of 6 Old 04-26-2014, 08:13 PM
I wouldn't suggest doing that because the plate that sits on top of the leaf springs wouldn't make good contact and possible break something or change spring rate?? Also do you have a 250 or 350??
post #6 of 6 Old 04-28-2014, 11:47 AM Thread Starter
Thanks for the responses, I have a 250. I cant exactly cut the coils, as i dont have any lol.I will try looking for a smaller block then, I didnt know it would sit lower than the front does. Towing doesnt really effect me, the most i tow is a small Uhaul.
2004 RCLB F250 6.0
