2004 on 35's..... question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-10-2014, 08:53 AM Thread Starter
Scolesy8's Avatar
I have a 2004 F250 that I currently have s leveling spring under and run 305/60/18's. I would like to move up to 35x12.50's and wonderingwhat everyone else did.... made up a lift or went all out on a 4" lift... any clearance issues or regrets with what you did??
Thanks
Zach
'04 F250 6.0 with some go go
Scolesy8 is offline
post #2 of 7 Old 04-11-2014, 03:25 AM
USAFBowman's Avatar
My truck is a F350 and all I did was level it and I was able to squeeze 35s in the wheel wells. My only issue is losing the ability to turn the wheel to full lock. They rub on the leaf springs
USAFBowman is offline
post #3 of 7 Old 04-11-2014, 05:54 AM Thread Starter
Scolesy8's Avatar
They only rub the leaf? My father's truck is a '99 F350 with a leveling spring, and we both have 33's but his still sits noticeably higher than my F250. I think that it can be done fine on a 1 ton but I don't think it'll work on mine...
Zach
Scolesy8 is offline
post #4 of 7 Old 04-11-2014, 09:03 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
If you have V codes a 3' hanger kit will clear 35".
If the tires rub a spring adjust the track bar to recenter the axle.
CT Performance, Inc. is offline
post #5 of 7 Old 04-12-2014, 04:08 AM Thread Starter
Scolesy8's Avatar
Hangers just up front or all around
Zach
Scolesy8 is offline
post #6 of 7 Old 04-12-2014, 06:14 AM
Quoted: 3 Post(s)
Just up front, rear block.
post #7 of 7 Old 04-14-2014, 09:09 AM Thread Starter
Scolesy8's Avatar
And this should do the trick then??
Zach
Scolesy8 is offline
