2006 f250 leveling kit no insulators - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-03-2014, 09:11 AM Thread Starter
Quoted: 2 Post(s)
I orderd a 2 inch on top of coil spacers they came with no insulators that go on the top of the spacers can you still install with out or no. An if no why not thanks guys the donut pices in this pic can I install with out them or no
2005-2014 Ford F250, F350 Super Duty 4wd - 2.5 FRONT Leveling Kit - 22970 | $129.95
89ezgo is offline
post #2 of 3 Old 04-05-2014, 06:06 PM
IIRC several of those spacer kits don't supply anything. You just pull off the isolator (or it comes off with the spring when you pull it out), slip the spacer on and install the isolator then the spring. I would personally use something just to be safe. Even some thick roofing felt would work between them. For the most part there is little movement since the spring pressure keeps it pushed up tight.
sw99 is offline
post #3 of 3 Old 04-05-2014, 06:19 PM
ZMANN's Avatar
Quoted: 1789 Post(s)
i would call them
while agree it shouldn't be a big deall that thick spacer might be part of the height they advertised and it's listed in the parts included so ??
Part # 22970
2005 - 2012 Ford F250/F350 Super Duty
2.5” Front leveling kit
Part # Description Qty.
22970-01 Front spacer 2
22970-02 Front isolator 2
22970INST Instruction sheet 1
MIRRORHANGER Rear view mirror hanger 1
WARNINGDECAL Warning decal 1
Congratulations
We Miss you Ronnie
ZMANN is offline
