6" Lift, how do i bring it down to 4"? (05 F350) - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-24-2014, 05:58 PM Thread Starter
MTBSully's Avatar
Quoted: 8 Post(s)
Bought my truck with a 6" lift and 37's. Picture below
Just a tad too big for my liking. Im looking to bring it down about 2" and run 35's. Anyone know what i need? The lift is a rough country and has the radius arm drop brackets and everything. Can i just remove one of the blocks or something in the rear and then swap the 6" springs for some 4" ones? What is my best option here?
Here is a shot of my rear axle so you can see my setup:
MTBSully is offline
post #2 of 9 Old 03-24-2014, 06:36 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
I think the best option with the rear axle would be to pull out that upper block. I have never really agreed with the idea of stacking blocks in the first place- I generally think it is better to install one larger block than stacking 2 shorter blocks.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 9 Old 03-26-2014, 04:52 AM Thread Starter
MTBSully's Avatar
Quoted: 8 Post(s)
Thats what I may end up doing. Any idea if I have to change anything with the leaf springs?
MTBSully is offline
post #4 of 9 Old 03-26-2014, 05:40 AM
GotTorque's Avatar
You should be able to pull out the upper block to get the height in the back you want, shouldn't need to mess with the springs. May need new U-Bolts as well...
As for the front is it all spring lift? If it is, your best bet may be to swap them out with a 4" lift coil and sell yours in the classified's.
Truck looks good tho man! I think I saw it on SVTPerformance already. Have Fun!
2006 CCSB PowerStroke
-PMM coolant filter and EGR delete
-Gearhead SRL tune
-5" Diamond Eye Exhaust
-20" BMF Novakane's 35" Toyo AT 2s
-All updated ford parts
-Chopped Running boards
-Gotta love the 6.0 haters...
GotTorque is offline
post #5 of 9 Old 03-26-2014, 05:57 AM
ZMANN's Avatar
Quoted: 1570 Post(s)
lift companies seem to stack ford rear blocks so they can sell the same lift for the 250/350
because from the factory they have a different size block for the 3/4 and 1 ton going with the stacked takes the variable out of the equation and then by leaving the OEM they don't need to add a jounce stop arm I think stacking is bullchit and should be illegal if it isn't already like I believe it is in my state
take your tape measure and look at 2" then decide if it's worth the effort and money to drop it that little
if so then like mentioned remove the top block /get new u bolts / trade or buy new coils/ may need all new shocks ,may need to un shim the carrier bearing , adjust drag link to center wheel , the rest may be ok but check for steering linkage issues(trac bar ,drag link clearance when done and may get an alignment
We Miss you Ronnie
ZMANN is offline
post #6 of 9 Old 03-30-2014, 06:57 PM
Beast2be350's Avatar
Damn your my twin!!
6" Lift, how do i bring it down to 4"? (05 F350)-imageuploadedbyag-free1396234573.973977.jpg
I wish I had your setup! I have the same lift with 35s but want 37s!
05 black xlt 6.0
03 turbo w/ wicked wheel
ARP head studs oem gasket
Egr delete kit
Blue spring
Bulletproof 48v FICM
6" rough country lift/ fuel kranks 20x11 -44 w/ 35s
Harley-Davidson head lights
K&N intake
4" straight pipe custom dual 6" tips
Pioneer 7" double din single 12" sub.
SCT live wire 5015 running Vivian's looney Wild tune.
Glowshift 4 pod. Egt, boost, trans, fuel pressure.
Beast2be350 is offline
post #7 of 9 Old 04-03-2014, 09:52 PM
adamread's Avatar
I wouldn't drive a truck w/ stacked blocks. It's ****ing hack as ****.
If you dropped the top block that'd knock you down 2". Lets see a picture up front. If you measure the front and rear to the wheel wells you can see if you really want to drop the back.
If you do, you can get 2.5" lift coils which are more like 3.5", Icon springs from Precision Metal Fab for next to nothing.
2006 F250 CCSB - Full PMF Suspension (3.5" 3-Link, 5.5" Traction Blocks, Drag Link, Track Bar & Steering Stabilizer) Bilstein 5100s, Hellwig's F+R, Centramatics, 20" Harleys, 35" Cooper Disco STTs, Nuc Bypass, Marine Charger, DDEC60 Block Heater, ARB w/ HID Hellas, BPD Water Pump, 5" MBRP Straight, SCT-X3 w/ IDP, H11's w/ OEM Gaskets
Dead in Water - Blew Turbo / IPR
adamread is offline
post #8 of 9 Old 04-04-2014, 11:49 AM
The quick answer is this: Remove the add-a-leaf, keep the all blocks and buy some 4" front coils.
See that leaf above the overload? That's an add-a-leaf from the lift kit. The discoloration from the other leafs in the stack is the indicator. MOST 6" lifts use the same block as a 4" lift AND the add-a-leaf for the additional height. Further, I'd keep the shocks, too. It's better to have shocks that are too long than too short. Unless you do some hardcore wheeling, those shocks will do fine until they wear out, then you can get 4" lift shocks.
As for the track bar, sway bar, and pitman arm, the pieces from the 6" lift should be the same as for the four. However, the drag link will need to be shortened for proper steering. Finally, have it re-aligned, there may be caster issues with the shorter coils. Although about all that extra positive caster could hurt is high speed cornering. Unless you drive it like a Mustang, that shouldn't be an issue.
One last thought: if the pin for the leafs is too tall when the add-a-leaf comes out, or the u-bolts too long for your liking, cut new threads and shorten them to your liking. I went from 5" blocks to lift springs and that's all I did to my long u-bolts.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 9 Old 06-16-2014, 05:10 PM Thread Starter
MTBSully's Avatar
Quoted: 8 Post(s)
Back up. Ordered my 35s today. Does the add-a-leaf add any height? The stock block appears to be 3.75" in height and the other block appears to be 3.125" in height. Should I just order one block? Whats with some of the blocks being angled? Help the newbie out here
MTBSully is offline
