winch sizes? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-24-2014, 08:44 AM Thread Starter
BWWilliams's Avatar
winch sizes?
what size winch are people running on these trucks? i need to know cause i have to size the custom bumper around it.
BWWilliams is offline
post #2 of 2 Old 03-24-2014, 04:21 PM
TerraScaper's Avatar
Typically you want 1.5 times the weight of your truck. That would put you at a 12,000 pounds. I would go with a 9,000 pound since they are a lot cheaper and you can always throw snatch block on an pull 18.000 if you really need to. I'm sure line speed will be a lot quicker with a the 9000. I think worm drive will be faster than the planetary gear setup. I believe most winches have the same mounting spacing for the bolts so you could change it later on.
2004 F350 ECSB Powermax, 4" turbo back with muffler, SCT Livewire w/ SRL, ARPs, EGR delete, Spring, Banjos, some other zoodads
TerraScaper is offline
