Harley grille with lights behind?? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By layson
post #1 of 7 Old 03-23-2014, 12:36 PM Thread Starter
Solo25's Avatar
As said I am looking to see if anyone has put lights behind their harley grilles and if so what kind and how much is blocked. This is where I sit now. Thanks for the help
Solo25 is offline
post #2 of 7 Old 03-26-2014, 09:29 PM
trophy_23's Avatar
I have a few Hella black magic lights that I'm going to install. They are dark so not as noticeable as th regular hellas. Here is am install that I am going to follow, same lights but mine are black magics. lights behind grille
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
post #3 of 7 Old 03-27-2014, 01:47 AM Thread Starter
Solo25's Avatar
Yea I saw that one I am just wondering how the light would make it thru the harley grille. Good luck
Solo25 is offline
post #4 of 7 Old 03-27-2014, 06:14 AM
trophy_23's Avatar
Is the harley grille not pretty much the same? I have the factory chrome grille which is the same as the harley grille just chrome and I think the light will be fine. Whichever one of is finishes first can report back... Deal?
High Idle
Duraflaps
Dually ID Bar
post #5 of 7 Old 03-27-2014, 06:16 AM Thread Starter
Solo25's Avatar
Yea they are the same. It's just the difference between the regular split bar grill
Solo25 is offline
post #6 of 7 Old 03-27-2014, 07:31 AM
layson's Avatar
Quoted: 84 Post(s)
Lights don't even know the grille is there.
trophy_23 likes this.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #7 of 7 Old 03-27-2014, 08:10 AM
trophy_23's Avatar
Here is another thread with the same grille I have (same as yours just chrome) Lights behind Grille
High Idle
Duraflaps
Dually ID Bar
