Led Fog light install? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-22-2014, 06:50 PM Thread Starter
Purchased a plug and play harness and two led fog lights. The harness has 3 wires which goes to a switch as well as a relay and a fuse. Now I want it to work on the factory fog light switch. How should I go about this.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #2 of 9 Old 03-22-2014, 06:51 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 110 Post(s)
Feedback Score: 7 reviews
The switch wire spliced into factory fog light wire or low beams if you didn't have factory lights.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
The Following User Says Thank You to powerstrokeshellback For This Useful Post:
20046.0 (03-22-2014)
post #3 of 9 Old 03-22-2014, 06:56 PM Thread Starter
Nice as simple as I thought, thanks.
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #4 of 9 Old 03-22-2014, 07:20 PM
Ontario Trucker's Avatar
Yes use the existing switch and wiring
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #5 of 9 Old 03-23-2014, 12:33 PM
Solo25's Avatar
What kind of fogs did you get?
Solo25 is offline
post #6 of 9 Old 03-23-2014, 01:54 PM Thread Starter
I did some research and if I just splice the power wires from the fogs to the LED lights they might cause flicker. That I don't want, is there a connection somewhere in the stock fog light harness that I can tap into using the switch wires from the switch provided in the harness. (Black, Bllue, White).
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #7 of 9 Old 03-23-2014, 02:48 PM
Why cant you use the wires that were on the original lights.....
post #8 of 9 Old 03-23-2014, 03:17 PM Thread Starter
It will work people just reported theycan cause flickering when the fog light switch is off and power is still ran to the vehicle. Maybe it was certain vehicle that does this.
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #9 of 9 Old 03-23-2014, 03:21 PM
OK thx for the info, good luck
