Would this bumper fit my 04? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-13-2014, 07:08 AM Thread Starter
HBandy's Avatar
HBandy is offline
post #2 of 8 Old 03-13-2014, 07:08 AM Thread Starter
HBandy's Avatar
HBandy is offline
post #3 of 8 Old 03-13-2014, 07:28 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Its not a ford pattern on the mounting tabs and doesnt look like its shaped for a ford, looks like its for dodge. Would it go on with mods...yes, will it bolt on...probably not and probably wont look aesthetically pleasing
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 8 Old 03-13-2014, 07:46 AM Thread Starter
HBandy's Avatar
It came off of a 6.4
Edit: scratch that, he cant remember if it was on a 6.4 or a 5.9. It came from a fleet truck.
HBandy is offline
post #5 of 8 Old 03-13-2014, 07:54 AM
Chapter Director
Quoted: 5 Post(s)
Well its not a 99-07 ford pattern then, sorry never personally seen a 6.4 mounting tabs. But then you still have your answer, it will probably go on because the mounting pads are the same position(minus the one offset hole) but will probably look goofy as hell if it even physically fits on, imagine putting a 6.4 bumper on your truck.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 8 Old 03-13-2014, 08:04 AM Thread Starter
HBandy's Avatar
From the front it looks like it wont look too bad on mine. And if it does I could just take it off and put it back out there. Just wanted to know if it would physically fit.
HBandy is offline
post #7 of 8 Old 03-13-2014, 08:16 AM
Chapter Director
Quoted: 5 Post(s)
Yes the mounts should bolt up minus one bolt on each side. Im just not sure how the top of the bumper(flat part) will line up with the bottom of the grill and headlights because 6.4s are flush across the bottom of the headlights and grill vs the 99-07 grill dips down below the headlights.
I just would hate to have you crack something trying to bolt it up. If youve never put one of these heavy bumpers on its a chore for sure just make sure you have lots of elbow grease to maneuver it or better yet a way to hang it from above
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 8 Old 03-13-2014, 08:37 AM Thread Starter
HBandy's Avatar
We have a chain hoist. I was gonna hang it up and get a look at how it would look on my truck before I ever put it on. I just dont want to load it up and take it home juat to see that it wont bolt on and have to take it back.
HBandy is offline
