2WD Lift - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-12-2014, 08:56 AM Thread Starter
2WD Lift
I've done a good amount of research over the past couple of years regarding lifting a 2WD. For my 06 (if not all Powerstrokes), it seems as if I have 2 options: either the 2" leveling blocks which I currently have; or a 6" lift - which I understand is basically a 4" lift when you factor in the 2" drop in the front.
My issue is that after a couple of years of running the polyurethane 2" leveling pucks, the front is starting to sag again. My question for anyone who's done this is: would I be better off using the 2" METAL spacers under the front springs? Do the metal spacers make for a much rougher ride? I'm also noticing that my alignment is getting worse.
Additionally, I've probably got 10-15k miles of life left on the tires. If I were to do the 6" lift, now would be the time, since bigger tires would be necessary. Any general opinions on this? I've seen some before/after pics and it looks pretty good. I'm just wondering if you would need to re-gear afterwards. Any opinions would be appreciated. I'm tired of that sagging front end.
dhr05b is offline
post #2 of 2 Old 03-14-2014, 12:08 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Yep, I replaced my poly pucks for metal pucks...
It bows out the springs un-naturally... More than I care for.
I'm saving for the 6" lift kit.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
