Wheel spacers - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By CT Performance, Inc.
post #1 of 6 Old 02-25-2014, 10:33 PM Thread Starter
jake_duet's Avatar
Wheel spacers
Got a set off 22x9 dick cepeks with a +19 offset. Was told 2" spacers would work. Any specifics i need to look at with buying spacers?
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
post #2 of 6 Old 03-12-2014, 02:36 PM
Quoted: 8 Post(s)
Contact this guy.
WheelAdapter.com is your number one source for wheel adapters, wheel spacers, used wheels, and wheel studs.
2005 F250 FX4 6.0 PowerStroke, Dashboss, Swamps 58V FICM, PHP Atlas 40 tune, Tony Wildman Extreme Tune, IPR Coolant filter, ELC Coolant, EGR....nevermind, updated stc, more to come!
Babyboy70363 is offline
post #3 of 6 Old 03-12-2014, 03:10 PM
john galt's Avatar
Quoted: 1089 Post(s)
I remember reading you have to get the ones made out of recycled space shuttle parts for them to hold up
but seriously I got some from ebay and they are fine
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #4 of 6 Old 03-13-2014, 06:07 AM
fdimeroller's Avatar
yeah, i've never heard of anyone having trouble with just the regular ones off ebay..
if you're talking about clearance.. all depends on tire size and lift really, with a positive offset the spacers should still be good
"FX40"
2006 F350 Lariat, Custom Painted, 2014 Front End Conversion, 14/12 Lift, 24x14 American Force Blade SS8 wrapped in 40x15.50 Toyos, 5" Magnaflow Straight Pipe, 8"x36" tip, SCT 5015, Train Horns, PA, Lightbars, etc.
fdimeroller is offline
post #5 of 6 Old 03-21-2014, 04:10 AM
Do u have to shave the wheel stud on 1.5" spacers?
GSE Nick is offline
post #6 of 6 Old 03-21-2014, 07:06 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Yes..we have spacers:
These are U.S. Alcoa 6061t6 billet aluminum, Lifetime warrantee, hub-centric and wheel-centric The spacers are roughly 3-5 times stronger than the Ford cast 20" wheels .
2" spacers will work without needing to cut off your existing wheel studs
We can get you 1.25-1.5" spacers but you will have to trim the studs shorter. But the back space with then be 4.5" and the rim will set like factory.
john galt likes this.
CT Performance, Inc. is offline
Tags
offset , rims and tires , wheel spacers , wheel spacing
