DIY spray in bed liner, U-pol Raptor and LED bed lighting - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 18 Old 01-31-2014, 05:19 PM Thread Starter
If anyone here is looking into a spray in bed liner then I would really suggest looking into the U-Pol Rapter bed liner. After researching it and seeing all of the jeep guys love it and put it thru all kinds of abuse, I figured its good for me. The hardest part was sanding the bed all down. Now on to the pics
I started off by removing the bed liner and found a hole lot of **** under there. Mostly leaves and mold from the water but also found some rust spots.
I cleaned and scrubbed the whole inside with simple green and got all of the crap out.
After that I sanded the whole bed down and hit all the areas with primer where I went thru to bare metal.
I masked everything off and put a tent up because the leaves were falling like crazy.
I sprayed the whole thing with raptor bed liner and this pic is immediately after I got done. you can see its looks a little uneven but after it drys it is all uniform finish.
After the coating dried I installed two 24in led strip lights under the bed rail
Fabbed5.0 is offline
post #2 of 18 Old 01-31-2014, 05:33 PM
brmccolley's Avatar
Job well done
That turned out really nice. Good job!
2011 F-250 King Ranch
Helpful info:
brmccolley is offline
post #3 of 18 Old 01-31-2014, 05:36 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1813 Post(s)
Feedback Score: 4 reviews
looks good man! I bet people were wondering what the heck was up with the tent you were backed under.
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #4 of 18 Old 01-31-2014, 05:57 PM Thread Starter
Thank you
Hahah my neighbors don't even question anymore, they know I'm always working on something.
post #5 of 18 Old 07-11-2014, 07:46 AM
Roll Tide Nation!!!
J_BAKE_04_PSD's Avatar
Quoted: 4 Post(s)
Garage
How are your led strips powered? I had led lighting in my last truck and absolutely loved it. Want to do the same for this one. Thanks.
2004 F-250 CCSB FX4
Blue spring upgrade, rebuilt '03 turbo, Edge CS, Cat EC-1, 7.3 fan clutch, '08 mirrors, 5100's
BPD Oil Cooler, blocked off EGR, Aluminum Radiator, Sinister Coolant Filter, X-codes
J_BAKE_04_PSD is offline
post #6 of 18 Old 07-11-2014, 03:25 PM
trophy_23's Avatar
Looks great! I finally got my bed lights in also. To answer the question above, I ran a 2 conductor wire (one to battery, one to upfitter) to a 3 way switch in the bed so it can be (on-off-on with upfitter). It works slick
john galt and bgraiders323 like this.
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
The Following User Says Thank You to trophy_23 For This Useful Post:
J_BAKE_04_PSD (07-12-2014)
post #7 of 18 Old 07-12-2014, 08:28 AM
Roll Tide Nation!!!
Quoted: 4 Post(s)
Garage
would you happen to have a pic of the switch and where it's mounted?
On my other truck, the relay was tucked behind the passenger tail light which connected to a spring switch (don't know if that's what it's called actually...lol) when pressed in would kill the power to the lights. Had to drill a hole for it to mount onto the body of the truck and where the tailgate would press the switch in when closed.
If I could do something differently, I would have installed a switch to toggle it on and off. Don't always need it on when the tail gate is down... THANKS!!!
2004 F-250 CCSB FX4
post #8 of 18 Old 07-12-2014, 11:39 AM
trophy_23's Avatar
I found a waterproof 3 way rocker switch online and it fit perfect in the existing hole in the bed. I was able to make all of the connections through the stake pocket in the bed rail and through the tail light. Up = upfitter controlled, middle = off, down = on
High Idle
Duraflaps
Dually ID Bar
post #9 of 18 Old 07-12-2014, 01:20 PM
john galt's Avatar
Quoted: 1387 Post(s)
looks nice I really like the led strips very cool effect.
I need to get around to wiring in my shell so the third brake light and interior lights work. for now I just have a battery powered camper light in the shell ... problem is it works too good you dont see it it is easy to find in the dark and out of the way. PLUS my mother inlaw gave it to me years ago before she passed so it is kinda like a silly memory thing.
soooo.... i just havent gotten around to any "upgrading" yet
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
post #10 of 18 Old 07-12-2014, 06:36 PM
Maybe one of you guys can do a write up on DIY install bed lights!!
LOL cause I want to do it!!!! PLEASE
bgraiders323 is offline
