Wheel flares to cover rust bubbles - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-30-2014, 08:42 AM Thread Starter
casper4203's Avatar
My '05 is starting to bubble the paint at the rear fenders. It's from the inner fender holding crud and rusting from the inside. Thought about pulling the bed off and dropping somewhere to let them do it right. Too many projects that require $$$ at the time.
Does anyone no of a subtle wheel flare that might cover this up for now? I don't really want a bunch of new holes.
Rich
EGR Delete
2005 Lariat CC/SB
5" Diamond Eye straight exh
Banks Ram-Air
Firetone Air-Bags
Edge Insight w/ fuel pres
and Pyro
Dummy plugs, Cat ELC
casper4203 is offline
post #2 of 10 Old 01-30-2014, 10:35 AM
After you cover it, you'll forget about it. Then, when it rears it's ugly head again, it will be a REAL MESS. Fix it now or buy a complete bed skin later.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 10 Old 01-30-2014, 03:00 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
I bought a gallon of POR 15 and sprayed everything under the truck including up around the wheel wells. I used a hole saw to cut the "spots" out and to add some drain holes by the inner wheel well seam and sprayed POR in and around. I then prepped and sprayed the rocker panels, bumpers, and wheel wells with U-pol raptor liner and finally installed some bushwackers.
The easy part is finding fender flares. But don't just bolt them over the rust. Cut out and seal the good metal so it doesn't spread. Sure there will be some quarter sized holes in the metal (sealed) under the flares. But I'm not going to spend $1000 for new bed or bedsides + paint on a vehicle that I don't use for "show".
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #4 of 10 Old 01-30-2014, 04:45 PM
Between the purchase price and add ons, my personal pride would REQUIRE me to fix the rust even if it meant a bed side or two. Now I will say that as long as you aren't painting over rust, POR15 is a good preventative measure.
Bushwhacker cut outs were about $1000 the last time I looked.
Karls03 is offline
post #5 of 10 Old 01-30-2014, 06:39 PM
Quoted: 60 Post(s)
Huh, bought my flares brand new for a little over $400 (for front and rear) and you'd never know there was a repair unless you ripped them off...
Repairing and repainting will only last about 5-6 years if you drive your vehicle during the winter with road salt.
post #6 of 10 Old 01-30-2014, 07:01 PM
Fender flares were about $400~$500 but the cut outs, as in require removing sheet metal to install, were as much as a lift. Hence why I lifted my truck when I did 35s.
Karls03 is offline
post #7 of 10 Old 01-31-2014, 05:47 PM Thread Starter
casper4203's Avatar
I am planning on doing the repair eventually. It just needs a temporary band-aid for now. If the bubbles don't pop the paint off I may wait a little longer.
post #8 of 10 Old 01-31-2014, 08:21 PM
I win....
cRaZy8's Avatar
Quoted: 41 Post(s)
Garage
Be careful, its probably not just the bed side, but also the inner fender/bed side.
That is a separate piece from the side, and this inner liner is the other half of the issue.
Mine was really bad, rust starting to bubble the fenders.
My crossmembers were pretty rough too.
I lucked out, my neighbors kid hit my truck, and paid for 75% of a new bed.
Talk to your local body shop, they hate doing rust repair jobs and usually charge a very large amount. Also, they will not warranty any of the work on rust repair- its an industry standard (I used to work in a body shop).
A good friend of mine owns his own shop, and he strongly recommended against repairing it.
Even with his "friend" discounts, the new 2013 bed, gate, and bumper was only $500 more than the rust repairs on both sides.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
post #9 of 10 Old 02-01-2014, 05:25 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
I'm in the market for a new complete bed myself. Not only do I have the rust on the wheel wells but my floor is has 2 holes and my rails are rotting too. It's not worth just doing bed sides, eventually the rest will go too
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 10 Old 02-01-2014, 07:33 PM
I win....
cRaZy8's Avatar
Quoted: 41 Post(s)
Garage
I have a guy in North MA that sells complete, new OEM beds, tail gates, everything.
About half the price of what dealers sell them for.
I was out the door with the bed, gate, bed caps, emblem, mounting bolts and nuts, $2800.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
