08+ tailgate with cam wire up to double din unit?? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Java
post #1 of 3 Old 01-24-2014, 07:01 PM Thread Starter
eddie06f350harley's Avatar
Hello just got my 08+ tail gate and it came with a back up cam, and i was wondering how or if anyone has wired one of these up to their aftermarket unit, u have a pioneer double din unit.. thanks guys
eddie06f350harley is offline
post #2 of 3 Old 01-26-2014, 07:21 AM
Java's Avatar
Here are the directions i followed to make it work. You should have 5 wires coming from the camera. White/brown-12 volt,black-ground,white/green-video+,brown/violet-video-,and black/white-will not be used. White/brown goes to a switched 12v, black goes to a good ground, on the video wires you cut end off a RCA cable,white/green goes to the inner wire,brown/violet goes to the outer wire,and the black/ white is not used. Then you just run to a switched 12v and run the RCA to your camera input on your head unit.
eddie06f350harley likes this.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
The Following 2 Users Say Thank You to Java For This Useful Post:
eddie06f350harley (01-26-2014), ZMANN (01-26-2014)
post #3 of 3 Old 01-27-2014, 09:00 AM Thread Starter
thanks brother!!!
