HID's, LED fogs & parking lamps- check! - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 12 Old 01-14-2014, 07:18 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
Finished up the install on my lights.
So its officical, ALL of my exterior lights are LED's.
I went with DDM tunings 55w 10k HID kit with slim ballasts. Great kit, very easy to install.
CREE Fog lights, spot pattern 30*, 6 LED's per unit.
Samsung amber 3157 LED parking lamps.
Installed last winter- Recon tail lights, LED license plate bulbs, LED 3rd light assembly (Recon knock-off).
The amount of light gained from the HID's and LED fogs is incredible. Probably 3-4 times brighter than stock.
I reused the stock fog light brackets. Removed the OEM fogs, used a piece of aluminum angle to go across them, allowing easy mounting of the LED units.
The LED units only 4 amps combined, I just reused the OEM wiring.
I also have a 7" light bar on order, that will go in between the fogs.
The pics from inside the truck are lights off, park lamps only, fogs only, then everything all together.
Name:	20140114_173359 (1200x675).jpg
ID:	226458   Click image for larger version
Name:	20140114_173411 (1200x675).jpg
ID:	226466   Click image for larger version
Name:	20140114_151043 (1200x675).jpg
ID:	226474   Click image for larger version
Name:	20140114_173538 (1200x675).jpg
ID:	226482   Click image for larger version
Name:	20140114_173525 (1200x675).jpg
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
post #2 of 12 Old 01-14-2014, 07:19 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
More pics.......
Name:	20140114_173449 (1200x675).jpg
ID:	226498   Click image for larger version
Name:	20140114_173430 (1200x675).jpg
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
post #3 of 12 Old 01-14-2014, 08:58 PM
eddie06f350harley's Avatar
nice upgrade I'm looking to do this to my harley very soon
eddie06f350harley is offline
post #4 of 12 Old 01-15-2014, 04:28 PM
Headlight questions... Did you go with the bi-xenon (hi-low) or single beam setup? Did you use relay to battery connection or direct power from headlight wiring?
Turn signals... Did you use a load balancer - resistor? If yes, where did you connect it?
2013 F350 Lariat CC SB Kodiak Brown
2007 F350 XLT CC SB 6.0 Dark Stone SOLD
2009 Heartland Razor 3612 Toyhauler
psdl6.0 is offline
post #5 of 12 Old 01-15-2014, 06:51 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
I went with the bi-xenon, with a hi-low. The high beam doesnt add much light, it seems to scatter a lot, and throw a lot of light up, and to the side.
I used the supplied relay harness. It is a very well made harness. Super easy to install. I just ditched the fuse holder they supplied, and used a beefier holder, with a water proof connection.
No resistors. I swapped out the flasher for the EP-27L. eBay has them for $14. I didnt need it with the Recon tails. But as soon as I went to the Samsung 3157's up front I had the hyper blinkers.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
post #6 of 12 Old 01-15-2014, 06:53 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
Forgot to mention- I also installed CREE flood lights in the rear, 4 leds per unit. Mounted to the bottom of the hitch tube.
Crazy bright. Freakin lights up the neighborhood.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
The Following User Says Thank You to cRaZy8 For This Useful Post:
skkele (01-16-2014)
post #7 of 12 Old 01-19-2014, 06:10 PM
Quoted: 83 Post(s)
Feedback Score: 3 reviews
Have any pics of the fog lights in daylight?? Which ones did you order??
2006 F250 8" inch Pro Comp, Top Gun Customz dual steering stabilizer, Bilstein 5125's, 4.30 gears Toyo MT 37's, Powermax, SCT X3 w/ Matt's 8k Tow tune, BPD 53 volt FICM, DC Power 185 alt, PMM coolant filter with Rotella ELC, Edge Insight CTS, MBRP 4", Line X'd bumpers, grille, and tonneau cover
villestrip is offline
post #8 of 12 Old 01-20-2014, 07:42 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
I didnt drive the truck to work today. Ill grab a pic or two tmrw.
I used these in the front:
This is the one going in the middle of those two:
These are the back up lights:
The front fogs were $50 each roughly.
The 7" bar was $52.
The rear lights were $60 for the pair IIRC.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
post #9 of 12 Old 01-25-2014, 07:00 PM Thread Starter
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
Here are the daytime shots Villestrip.
casper4203 and bgraiders323 like this.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
cRaZy8 is offline
post #10 of 12 Old 02-10-2014, 04:35 AM
ZackMicF's Avatar
Quoted: 28 Post(s)
can you post some pics up close with the lights off?
im stuck between these and a 20" light bar,
I like the factory fog light look a lot better then that 20" setup and besides this would be a way cheaper route,
ZackMicF is online now
